Popping and backfing under boost
Old Apr 11, 2009 | 03:31 PM
SuperC1's Avatar
Default Popping and backfing under boost
Just finished my new turbo build and my question is what could be causing it to be breaking up and popping when it goes to wot. If I ease into it from a roll it does fine but if I nail it from a dead stop it starts breaking up, mostly at high rpm. I changed out the plugs and put some 8's in gapped @.025, and new wires, etc but I'm still having the same issue, what could be wrong?
Old Apr 11, 2009 | 05:35 PM
conan's Avatar
Has it been tuned?
Old Apr 11, 2009 | 06:34 PM
Louis's Avatar
With a PT88, I hope it would be tuned!!
Whats the mixture like? How much HP roughly? Valvetrain setup and boost levels?
There are a lot of things it could be, more information helps
Louis
Old Apr 11, 2009 | 09:24 PM
theblur98ss's Avatar
What's your fuel system and do you know what the pressure is doing while it's acting up?
Old Apr 12, 2009 | 09:57 AM
SuperC1's Avatar
Yea its been tuned, I've already decided to go with twins, but I was thinking it would do fine at low boost with the single pump. Everyone I've talked to says it's emissions related. ie plugs, wires, or coil packs.
It made 531rwhp at 50% throttle on the dyno before I had to let out of the throttle, so the pump is definatley on the edge.
Old Apr 12, 2009 | 10:08 AM
SuperC1's Avatar
Louis
It's between 11.5 and 11.8 on the mixture, everything looks good, just starts breaking up around 6K.
Old Apr 12, 2009 | 10:26 AM
Louis's Avatar
single pump? Thru a TH400, its done. Have you watched the mixutre when it does that, on a logger? It will break up and change so fast, you need to see it on a logger.
Old Apr 12, 2009 | 10:37 AM
SuperC1's Avatar
It starts breaking up at 55psi even though the mixture is 11.8-11.5 afr at 5800 to 6000 rpm. The pump is a racetronix pnp setup with a hot wire kit. I'm looking into running a second pump off a hobbs switch, where can I purchase one of those?
Old Apr 12, 2009 | 10:39 AM
topend's Avatar
check for vacuum leaks, your coldside piping, intercooler for leaks.
Old Apr 12, 2009 | 10:43 AM
Silver_TransAm's Avatar
If your running a single fuel pump it is most likey that. I maxed mine at 540whp and had to let up on the dyno. I would think 11.3 would be more ideal. 11.8 seems a little on the lean side.
Old Apr 12, 2009 | 10:52 AM
SuperC1's Avatar
It was dropping down to 10.5, so I had to lean it out a little, it was still breaking up though, I let out at 531 on the dyno cause it wouldn't rev any further.
Old Apr 12, 2009 | 11:05 AM
Photochop's Avatar
Could be too much fuel at that RPM (tune issue). I had similar problems with my setup recently, its been tuned but I thought I'd try a set of TR8s...good idea from what I 'heard', but it didn't wanna keep a set of TR8s in it at all, fouled them in about 10 mins of driving and was doing the popping thing under about 3/4 throttle and 4+ psi of boost. Put TR6s gapped at .028 (gapped tight as it was blowing out the spark at .035) back in the car and its driven great since. You might try the same or maybe try a TR7....the 8s are very cold and may be too cold for your app.
Old Apr 12, 2009 | 11:23 AM
Good point. I tryed tr8 plugs in my car and I started having problems and when I pulled them the looked bad so I put a set of tr6 plugs in it and been running them ever since. The tr8 is a really cold plug.
Old Apr 12, 2009 | 11:29 AM
U-Luze's Avatar
Default Popping
What kind of coil packs you have? I had the same problem with my procharged car, It turned out the car packs didnt have enough stuff to keep it goin. Switched to truck packs and problem solved go's to 7000 no problems not stumbling or anything like that.
Old Apr 12, 2009 | 02:42 PM
SuperC1's Avatar
Running stock coil packs right now, a set of truck coils would be nice though. But I was told that the stock coils would work fine, is that a bad idea?
Old Apr 12, 2009 | 02:44 PM
SuperC1's Avatar
Its running the same way it was with the tr6's.
Old Apr 12, 2009 | 04:25 PM
Well the stock coils should have no problem with your setup.
What kind of plug wires do you have?
What valve springs do you have?(valve float maybe)
What do the plugs look like after if acts up?
Any more info on your setup might help.
Old Apr 12, 2009 | 10:12 PM
SuperC1's Avatar
Plugs look clean, the wires were msd street fires custom made because the original msd's weren't long enough. Been thinking about going with some 8.5mm's though and wraping them with some heat shielding tape. Valve springs are patriot dual gold. I'm leaning towards the wires being the issue though, cause the pressure drop was very little. Adding twins was already in the making, just need two pumps to go in the bucket, going to dump the racetronix single. I got some -8 and -6 steel braided lines here already and boost reference regulator with rails ready to go. Just hate to tear down the car again.
Old Apr 12, 2009 | 10:28 PM
SincalT/A's Avatar
What is your voltage reading through all this?
Old Apr 12, 2009 | 10:33 PM
charcold-bowtie's Avatar
sounds kinda like mine when I first ran into burst knock problems in the tune.
