Speed density or Mass air flow
Old May 4, 2009 | 05:54 PM
  #41
99Ls1fever's Avatar
Originally Posted by vaticano
See post above yours.
Once you figure out how the software works, it's not hard at all.
I own a shop licensed HP Tuners cable, but don't use HP so I have been hessitant to use it so I just let our friend use it.
So, Can I just have your shop tune my Car? I have meet you before on the 84th and fedral cruise I had the white z28 with the black hockey stripes on it.
  #42
vaticano's Avatar
Originally Posted by 99Ls1fever
is there a max point for your stock MAF Sensor in reguards to Horse Power?
It stops reading at 512 g/sec. for LS1's. I've heard that equates too 500 HP. Then it is no longer used for fueling.
Old May 4, 2009 | 05:56 PM
  #43
vaticano's Avatar
I don't have a shop, I bought the software as an investment for another shop that went under. He lost the business, I got stuck with 9k worth of software.
Old May 4, 2009 | 05:57 PM
  #44
99Ls1fever's Avatar
So, just a question. How is Clint Tuning Chad's car then since it is at 640 hp? Chad has the stock GM MAF sensor. And I know Clint has tuned his car.
Old May 4, 2009 | 05:58 PM
  #45
99Ls1fever's Avatar
So, how much do you yourself charge for a tune?
Old May 4, 2009 | 06:07 PM
  #46
vaticano's Avatar
I don't. I have only tuned my car. I would hate to tune someones car, have it brake, and they blame me. So I have been trying to sell the cable for over a year. I work all week so I don't have alot of time to for tuning. But I have been thinking about starting.
They way to get the car to run when the MAF is maxed out is throught the PE table. Then you just add fuel based on rpm, it's not an exact sience but it works.
Edit: Also if you take away the 20% correction factor he is just over 500
Old May 4, 2009 | 06:11 PM
  #47
99Ls1fever's Avatar
Cool, just woundered. It nice to have someone help you with these questions then the uh and bs lines they give you face to face or over the phone. That was kinda why I have been tryong to find info out on the subject of SD and what is the best way to tune. thanks
Old May 4, 2009 | 06:20 PM
  #48
vaticano's Avatar
No problem.
Old May 4, 2009 | 06:25 PM
  #49
99Ls1fever's Avatar
You going to the track this year or on crusies? 84th and Fedral thing?
Old May 4, 2009 | 06:27 PM
  #50
vaticano's Avatar
Yes. I just got the car up and running. Now I just need to clean it, it's a mess.
  #51
99Ls1fever's Avatar
What did you do to it? Must have added something
Old May 4, 2009 | 06:34 PM
  #52
vaticano's Avatar
I put a SDCE bracket on it. Which did nothing for increasing my boost. I had to get a new blower crank pulley because the bolts broke off the other one. I rebuilt the front calipers, I burned them up while tuning it. Stainless brake lines. New high flow hydraulic line for the clutch. I'm hoping for much better times this year, the clutch was killing me last year. As well as the dragging brakes.
Old May 4, 2009 | 06:39 PM
  #53
99Ls1fever's Avatar
Sounds like a busy winter!!! what clutch did you go with?
Old May 4, 2009 | 06:51 PM
  #54
vaticano's Avatar
Still useing the Spec stage 3, my issues were the restrictive lines. But, I think a new clutch is in the near future. Went for a test drive yesterday, and it seems to be slipping a bit.
Old May 5, 2009 | 03:30 PM
  #55
99Ls1fever's Avatar
That Sucks!!! What Clutch are you going to go with now? Sticking with Spec???
