Milky oil out tailpipe
Old Apr 16, 2009 | 04:14 PM
pdasterly's Avatar
Default Milky oil out tailpipe
New engine getting milky oil out the exhaust. Sts turbo. Enginw oil is very clean
Old Apr 16, 2009 | 04:53 PM
Super Slow SS's Avatar
have you separated the cause from the turbo or the engine?
Old Apr 16, 2009 | 05:01 PM
Blackbird's Avatar
water + oil
is it constant or just some on startup?
you will get a fair amount of water out the exhaust on initial startup so if it's mixing with oil leaking thru the turbo then you get your milk.
I ended up with a restrictor on my oil feed to stop the oil leaking, maybe you need to look into the same?
Old Apr 16, 2009 | 09:31 PM
pdasterly's Avatar
Looks like water mixing with oil. I will try the restrictor
Old Apr 21, 2009 | 03:31 PM
pdasterly's Avatar
i have the restrictor in the oil supply block, i also have a restrictor on the oil inlet supply on the turbo itself. I'm still getting oil out my exhaust, what should i do next?
Old Apr 21, 2009 | 04:03 PM
Boostaholic's Avatar
Where did you get that little block and restrictor setup?
Old Apr 21, 2009 | 04:18 PM
slow67's Avatar
Gingervitis Addict
Look at the properties of the picture
Old Apr 21, 2009 | 05:23 PM
Blackbird's Avatar
so either pump is faulty or the turbo is messed up would be my best guess. hopefully others more knowledgeable with the internals of a turbo will chime in.
also are you constantly getting the milk out the tail pipe? if so then that's likely a blown head gasket and nothing to do with the turbo and it's oiling.
