Turbo Tech kit
Old Oct 28, 2003 | 08:32 PM
02BlackWS6's Avatar
Default Turbo Tech kit
Whats the max boost a T-60 will run on our LS1's? How much is the T-76 upgrade? Where's the best place to buy the kit?
Old Oct 29, 2003 | 02:06 AM
LSs1Power's Avatar
I would stick with a F1 procharger with ur future setup. The T-60 wont be enough for a forged 370CID with low C/R. The T-78 will make some serious power, but i just saw one car soo far doing over 500rwhp with their kit. F1 with 12-15psi and 8.5C/R 370CID u will be between 600-700rwhp. Good luck.
Old Oct 29, 2003 | 02:24 AM
02BlackWS6's Avatar
OK sounds good..thanks for the tip.
Old Oct 29, 2003 | 10:36 AM
smokinHawk's Avatar
you should be able to push out a little under 500rwhp with the t60 kit
not sure how much the t76 upgrade costs
i know detroit speed works carries the kit you can also get it directly from turbotech, they would know pricing.
Old Oct 29, 2003 | 08:07 PM
MYTURBOT/A's Avatar
the t76 upgrade is $1400.00, the max boost my 60 will push is 10psi anything above that drops off at high rpms.
Old Oct 30, 2003 | 01:17 AM
02BlackWS6's Avatar
Well thanks for the info. but i sent in my P1SC for the D1SC upgrade I know that blower can handle my setup. But I weighed the options and decided to stick with stock cubic inches. And put the money in other things. Put the D1SC is this gonna be the better blower from wat I've seen even with stock cubes. Forged bottom end , ported 6.0 heads, and blower with the D1SC it should still fly
