supercharged + nitrous
Old Apr 22, 2009 | 10:50 AM
daniel6718's Avatar
Default supercharged + nitrous
if i were to put a d1 kit on a 355 lt1, looks like it will be outa steam somewhere in the 700's so to make more id like to spray it with maybe 100 shot, assuming it doubles i should make 900ish
what ill effects do you have with supercharged and nitrous cars, i know with turbos you run into backpressure problems when your maxed and then try to spray
Old Apr 22, 2009 | 11:07 AM
viper9403's Avatar
Properly setup (8rib, overdriven balancer, etc..) the D1 should be able to make high 700's and some I've seen make in the lower 800's. With that being said I would overspin the D1 with an 8" balancer and a 3.5" blower pulley. Then spray an 100 shot on top of it. Boosted cars love n2o. Should be able to pick up over 150rwhp on a 100 shot!
Old Apr 22, 2009 | 11:08 AM
viper9403's Avatar
Also the biggest herdal you will have to overcome is the fuel system. This will require a great deal of fuel.
Old Apr 29, 2009 | 04:27 PM
99Ls1fever's Avatar
I spray a 100 shot on a maxed out g trim kit and have never had a problem. There is a number of us who race every weekend at the track with either a procharger, vortech or kenny bell and well all spray on top of our blowers. The rule is two power adders max.
Old May 1, 2009 | 04:26 AM
EPP's Avatar
EPP
I agree, the car is going to need a good fuel system which isn't cheap. 700 rwhp or so can get by without going with a whole new fuel system, but somewhere past this number requires a lot more fuel. Bob
Old May 1, 2009 | 10:56 AM
Bad30th's Avatar
Wet shot is easier to provide the additional fuel.
A 50 shot (with about 900psi bottle pressure) on top of my 8psi of boost gave me an additional ~50rwhp and ~125rwtq on a Dynopak dyno. N2o torque multiplication on top of boost is pretty stout...
Rob (Bad30th)
Old May 1, 2009 | 12:27 PM
Drewstein's Avatar
My 100 shot picked up exactly 100 peak to peak FYI.
I run a separate fuel cell so I don't tax my fuel system.
Old May 1, 2009 | 12:55 PM
V6 Bird's Avatar
Theres NO WAY in hell you will be out of steam at 700 hp on a D1. We just made 1000hp with a true D1 unit spinning it to 8000rpms. Something is not correct with your setup for sure.
Old May 1, 2009 | 01:13 PM
Louis's Avatar
Its a planned setup from what I know, its not done and running yet. I think you will get where you want to be Daniel on boost only, just leave the kit on the car in case you need it.
I would find a 1 7/8 or larger header though for those power levels.
Old May 1, 2009 | 02:14 PM
ZLEEPER's Avatar
Is there any other risk to spraying a boosted application, other than the obvious form increased stressors on moving parts..(provided fuel is adequate)
Old May 1, 2009 | 02:28 PM
daniel6718's Avatar
hmmm well ive read overspinning them some mid 800s is about it...
im not a fan of superchargers at all...but lt1 turbo kits suck...not one nice one that id be happy to run...
and the headers is a whole nother challange
this whole idea might get scrapped though since lt1 computers can only read 2 bar...it wont make the power i want at that, not a huge fan of dropping the money for bs3...
Old May 1, 2009 | 04:09 PM
99Ls1fever's Avatar
Agreed 100% I had to run to Walbo 255's in tank and bigger injectors it costed me around 700 bucks for injectors and 2 Walbo 255's. That is a definate thing you dont want to short cut or not upgrade!!!
Old May 1, 2009 | 04:36 PM
Drewstein's Avatar
Sorry but my D1 was DONE at 750rwhp in my well setup 402ci application. I'm pushing 14psi through it with a flip drive. I may be able to eek out a little more with some gnarly AFR225 type heads instead of the 6.0 heads I'm running, but the D1 is huffing and puffing.
I through a 100 shot on the car instead and the power under the curve now is retarded.
Old May 1, 2009 | 11:20 PM
BOOSTED1995's Avatar
awesome! How much timing do you pull out of it on the button?
Old May 3, 2009 | 09:03 PM
daniel6718's Avatar
hope your at work tomaro...got some chit chatting todo
Old May 4, 2009 | 08:39 PM
Rickys S/C Z28's Avatar
wow you guys are getting big power out of the D1
Old May 4, 2009 | 09:33 PM
TheBlurLS1's Avatar
That's what she said...
Like they said above, fuel is going to be key.
Best bet would be to run a stand-alone tank with the spray and fill it with C16 or something.
