undersquare vs oversquare
Old Oct 29, 2003 | 08:10 PM
Excal's Avatar
Default undersquare vs oversquare
let's say i have a boosted engine (turbo)...
1- will adding cubes just give me loads of torque down low and nothing more? (this being what i don't want)
2- what would promote high Rpms and top end more, a stroker or Bored?
Old Oct 29, 2003 | 11:41 PM
Keith's Avatar
Conventional thought uses as large as a bore as possible for high RPM power.
e.g. F1, CART, Motorcycles, IRL.
Old Oct 30, 2003 | 01:07 AM
ChrisB's Avatar
With a turbo the #1 factor is going to be the turbo you choose - the intake compressor wheel will pretty much fix how much air you can flow (HP potential) and the exhaust side will determine when it spools up, becomes a restriction, etc.
There is no point in worrying about minute differences is bored vs. stroked, etc. motors in this case - larger cubes should help you spool up slightly sooner - but then you could just change the a/r ratio slightly and keep the same spool up with more top end boost.
Basically the answer to the question is the turbo you choose is going to be the over-riding factor determining all of that. Everything else is secondary.
