Dry sump systems?
Old Apr 30, 2009 | 06:14 PM
z28adiction's Avatar
Default Dry sump systems?
I was just wondering what dry sump systems you guys run on your high hp turbo engines that are around a 402 cu/in. Links would be great thanks.
Old Apr 30, 2009 | 07:34 PM
Turbo LS1 SS's Avatar
i know this guy local to you. he has a killer 408ci car with a turbo. he called me up today to remind me that he already told you a dry sump is unnecessary for what you are doing
Old Apr 30, 2009 | 11:57 PM
haha i know i know. i was just curious since it pulls a vacuum on the crank case which is nice to have under boost. I would love to experience this hulk like power of your car, but the poor girl is always having issues lol. i think you have her pretty well worked out for this year, maybe actually get to fine tune all the little things. The whole car has been redone.
Old May 1, 2009 | 02:00 AM
chuntington101's Avatar
+1 im intrested in what kits people are using. Could be the ultimate answer for all rearmount guys!!
Chris.
Old May 1, 2009 | 06:24 AM
Fireball's Avatar
if thats all you want, buy a vacuum pump...its a helluvalot cheaper than a full dry sump setup
FWIW, I'm still wet sump too
Old May 2, 2009 | 12:30 AM
anyone out there have any links?
Old May 2, 2009 | 12:43 AM
[QUOTE=Fireball;11524613]if thats all you want, buy a vacuum pump...its a helluvalot cheaper than a full dry sump setup
Yea this is very true. by the way your car is a work of art also i made your launch pic my backround on my comp the night before you posted on my thread lol
Old May 2, 2009 | 01:03 AM
OKcruising's Avatar
I say do a vaccuum pump if it's merely that your after.
Why exactly do you want dry sump? If its a full out race motor, it'd make a hell of a lot more sense to do as its not very cost effective for extracting the last bit of horsepower, but very effective at saving engine oil starvation
There's ARE,
Aviad,
Moroso,
and some others that escape my head at the moment.
Price range: It's the plumbing, misc stuff and labor that also needs to be factored in.
Old May 2, 2009 | 08:31 AM
Phil99vette's Avatar
7 Second Club
If you want to do it right....Use a Starr standard vacuum pump and either a Barnes or a Stock Car products external oil pump. You'll still hold the oil in the pan just have a much better oil supply. I did a 5 stage dry sump with a 4 section divider pan and its expensive.
Custom Pan: 600-1000
Mandrel: 300
Dry sump pump: 1000-1500
Oil canister: 500-800
Lines and fittings: 500-800
Oil filter relocation: 100-300
Old May 2, 2009 | 08:33 AM
7 Second Club
http://www.starvacuumpumps.com/catalog.php
http://www.stefs.com/products.html
http://www.jonesracingproducts.com/
http://store.summitracing.com/partde...5&autoview=sku
http://www.barnessystems.com/
http://www.scpdrysumps.com/
http://pumps.scpdrysumps.com/
I'd call Chris Straub and enlist his help for a dry sump if you go that route.
Old May 2, 2009 | 03:46 PM
what vacuum pumps do you reccomend to pull vac. on the crank case?
Old May 2, 2009 | 05:46 PM
Fireball's Avatar
star machine.
Old May 2, 2009 | 08:06 PM
The standard pump or the mountain motor pump?
Old May 3, 2009 | 07:04 AM
Fireball's Avatar
I have the standard pump.
Old May 3, 2009 | 11:02 AM
ok thanks for your help.
Old May 3, 2009 | 12:33 PM
Denali08's Avatar
Any pics for the vacuum pump mounted and what does it require to fit f-body?
Old May 3, 2009 | 01:07 PM
Fireball's Avatar
welded a bracket to bolt it to on the frame rail (since my motor is on plates)
