My 91mm turbo kit
Old Aug 28, 2009 | 08:26 AM
  #161
koolrayz's Avatar
Thanks for all the kind words!
I hope to be out again tonight with some more boost if the rains stops. Car is in the parking lot and its raining like hell
Old Aug 29, 2009 | 10:15 AM
  #162
darooke's Avatar
get a better camera man. That video was crap. Maybe get halfway down the track in the stands and video the runs. Then we can see the times and traps. Great car. I am impressed with the fab work. Good luck tonight if you get there.
Old Aug 30, 2009 | 08:01 PM
  #163
koolrayz's Avatar
Wanted a turbo blanket but I am low on funds after finishing the build. I found this material that we discontinued at work. We used it on the normalizing furnaces which we run over 1700F so I know it will workk. It was A bitch making the template while the turbo was installed. it was even harder to install. I will make a better one over the winter when the turbo is out. This will work for now and the materail seems to work great. The real test will come at the track but right now I brought the cat up to temperature and there was NO heat radiating through the blanket. I need to look up the material specifications. It is a multi layer cloth with a rubber like coating. I painted it with high temp black paint but it doesn't seem to adhere very well.
Old Aug 31, 2009 | 04:40 PM
  #164
98Camarod's Avatar
I think the problem with your blanket is that it's not thick. My blanket you can touch while the it's running and not burn yourself, granted I have a gt70
Old Aug 31, 2009 | 04:47 PM
  #165
koolrayz's Avatar
See how close the turbine is to the balancer? A regular blanket will not work. I feel NO heat coming through this material. It may look thin but it is incredibly dense
Old Aug 31, 2009 | 05:24 PM
  #166
98Camarod's Avatar
I didn't even see that, good call
Old Aug 31, 2009 | 07:30 PM
  #167
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That looks like an absolute pain in the *** to assemble in the car.
Old Sep 2, 2009 | 08:41 PM
  #168
grp3569's Avatar
incredibly dense
kinda like your ols ***
Old Sep 5, 2009 | 12:41 AM
  #169
Shearer's Avatar
Ray. Craig isn't pleased still. He says hike up the panties and turn the boost up. He'll buy the box of Depends when you do decide to give it hell.
Wish I could have been there tonight. Damn weddings.
Old Sep 5, 2009 | 02:48 PM
  #170
koolrayz's Avatar
Tire shake fucked me out of an 8 second pass on the 9.030 run.
Dragway 42 on a TnT night is just not the place for a car like mine
Best part is thats only 17psi and only 16* of timing, on a 295 drag radial. It has alot left in it.
Old Sep 5, 2009 | 04:48 PM
  #171
trigger1's Avatar
This is the first time I've seen this thread. Good work guys. Ray, I believe we crossed paths years ago down when I was in Columbus having my car dynoed. You guys were just pulling in as we were coming off the dyno. Anyway, again, good work.
Old Nov 10, 2009 | 02:09 PM
  #172
Blue72's Avatar
Very nice!!! Looks great. Ron is a great fabricator. I run one of his manifolds on my GT42 powered Eagle Talon. He really does beautiful work!
Old Dec 17, 2009 | 10:38 PM
  #173
bad6as's Avatar
race weight?
Old Dec 17, 2009 | 10:41 PM
  #174
Ws6kid.'s Avatar
wow. best turbo set up ive seen in a while.
Old Dec 18, 2009 | 07:09 PM
  #175
koolrayz's Avatar
Originally Posted by bad6as
race weight?
Race weight at norwalk the day I threw the rod was #3825
I hope to get #200 out of it this winter. The aluminum block I bought yesterday is a good start
Old Jan 19, 2010 | 07:39 AM
  #176
chuntington101's Avatar
koolrayz, did you have any luck with the specs of this material? any ideas where you could buy this stuff? Just thinking it would be a nice workable alternative to header wrap.
Cheers,
Chris.
Old Jan 19, 2010 | 11:52 AM
  #177
koolrayz's Avatar
Cheers,
Chris.
Turns out it was discontinued, it was also very pricey when you could get it
Old Jan 19, 2010 | 08:44 PM
  #178
Rickys S/C Z28's Avatar
man nice *** set up!!! the thing dreams are made of!!!!!!!!!!!
Old Jan 20, 2010 | 07:03 AM
  #179
Is there any other matterials that could be used? I have heard great things about these Inconel heat shields, but agian they cost a fortune....
Chris.
Old Jan 20, 2010 | 09:31 AM
  #180
Shearer's Avatar
Chris,
Those heat shields are worth the money.
