STS Turbo Kit
Old Nov 5, 2003 | 11:11 PM
  #61
verbs's Avatar
Originally Posted by Excal
it won't boost as fast, however lag is .01 something seconds so IT will feel like no more.
all boost by 2800 rpm? faster than plenty of applications. (check the dyno)
and it comes off in an hour and change...that ALONE is a brutal advantage.
For example..some of u might check out some dude who put 14000-15000 on his QMP and is makingless power than the lt1 with the STS.
the lt1 has no headers or cam either. not sure about heads.
right, the STS is not a race kit, but for an f-bod it is the most money/power efficient.
by that "efficient" logic, no one should own a supercharger because they are much more less efficient than turbos, of course that argument falls flat when u have that FIR supercharged convertible bird in the 8s where turbos have yet to reach on this site.
also the 60-1 qmp kit..i still haven't seen anyone take that 15 psi even..u think it will support 600rwtq? the sts kit does, on an lt1 again. with an 60-1 (whata conicidence) except it has no intercooler and rear mounted.
although if anyone wants to, the intercooler can go in no prob, and it will be superior because of the methanol..
if me planning to buy i kit is bias, the so be it. it's the easiest way to turbocharged power by FAR.
also the lightest way, (light on my wallet). i don't want to weld. i don' want to get charged or travel thru states to get this installed.
i don't want to pay for tuning. i don't want to be turbocharged and not have to have a an aftermarket fuel system, at least not rigth away.
check turbolocity, or cartech the new kits are the same ol..$6500 and have to deal with cracking headers ect ect.
This kit lags no more an .01 seconds on other kits? Did you actually sit in cars and time this with a stopwatch?
No tuning on a turbo? $15K QMP kit? 60-1 turbo? you don't have a clue.
Old Nov 6, 2003 | 12:35 AM
  #62
Ferocity02's Avatar
Anyone have a price range on this thing yet?
Old Nov 6, 2003 | 12:44 AM
  #63
Turo's Avatar
the lt1 is $3500, still waiting for info on the ls1 kit
Old Nov 6, 2003 | 11:05 AM
  #64
purevilss's Avatar
Originally Posted by Donate52
well, i just got done reading a post from sffba.com of the lt1 that installed this kit, and he went from 273hp/303tq to 353hp/390tq (remember, this is an LT1, not LS1), seeing 4.9 psi with only an inline pump and NO TUNING!!! IMO, those are some great gains. im definitely keeping an eye on this system, i might have to get one for myself . but you guys have to see this kit for what it is, an affordable alternative to the front-mounted ls1 turbo kits out there. it may not be as powerful/efficient, but its not as expensive either .
http://www.discountchips.net/2kss/vi...bolt1final.mpg
ohh yeaaaaa
I'd have to say that the 512 hp and 600 ft/lbs that the STS kit produced on the LT1 with just 1.6 Rockers, Forged pstons, and an MSD is not to bad and seems to be pretty powerful. I mean realy on 91 octane and 14 psi, thats awesome for an auto to dyno thats mostly stock. I have seen several 12-14 psi LT1's with mildly built motors on the dyno and not one hit the 500 mark.
Old Dec 30, 2010 | 05:53 AM
  #65
JoshuaGrooms83's Avatar
well since i hav enothing better to do lol
Anything new to post about STS turbo kits on LS motors since 2003
Old Dec 30, 2010 | 11:53 PM
  #66
sbcgenII's Avatar
Since you dug of a post from 2003 I am assuming you searched but you still Fail.
Old Dec 31, 2010 | 03:17 AM
  #67
Fail... not so much.
Actually ive been doing a little research but wanted alittle more input from people that have it on their rides. Since they first started i noticed that they now provide a FMIC, a Subframe type charge pipe on the driver side, a hidden and tuck up fiter position, and with upgraded kits injectors and meth kit. I want to say they that some sell with a fuel system upgrade aswell but id have to read around again. If i get ahold of one, im gonna do what one guy did and make a stand alone oil system with a cooler. Ive also learned if you modify how the turbo sits on the exhaust side, you can get it to tuck up under the car even better, reducing chances of hitting anything. I also thought about doing belly pans under the car to reduce under car drag and turbulance and if one was place under the rear of the car while a turbo was there, that would help alos isolate the turbo from the elements a litte more as well. Ive also learned that at 4-5 psi you can acheive 450ish range of power and 500ish on 8-9 psi with meth. ANd thats not just what STS says but alot of other people that have owned it. Ive also learned that the oil system (in sts stock form) sucks and that the pump likes to go out ocassionaly. THat and the PCV hook up needs to be corrected. On the plus side sts improved their oil return at the cap. but if you do a stand alone system on yours you bypass this all together, which you dont have to run the return line and no tapping into the engine oil. you ca also upgrade the turbo either through sts or on your own. Wrapping the exhaust provides gains and a tune can save your life No STS is not the best turbo system in the world but yes it works and sith some tweeks and better hose clamps and couplers, can perform quite well.
so did i miss anything? lol
Old Dec 31, 2010 | 06:27 AM
  #68
Cold06's Avatar
Originally Posted by sbcgenii
since you dug of a post from 2003 i am assuming you searched but you still fail.
facepalm!!
Old Dec 31, 2010 | 07:19 AM
  #69
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Yes, move the turbo up to the front of the car. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Dec 31, 2010 | 07:39 AM
  #70
but then it wouldnt be an sts now would it?
Old Dec 31, 2010 | 09:50 AM
  #71
ZGOBYBY's Avatar
I own an STS kit, and it's on my '95. Yes, A LOT of tweeking needs to be done to it. I also have a FMIC with my kit. My car is done for the winter because the seals on my GT40 blew, and I am pretty sure I blew a piston ring after only 1,000 miles with the kit installed at 6 lbs.
Old Dec 31, 2010 | 10:58 AM
  #72
I plan to do one for my 98 ta
Old Dec 31, 2010 | 02:12 PM
  #73
Fb0dy0nly's Avatar
Zgobyby, that IC setup under the front clip in ur sig looks so nice! makes me want to hook up a nice blower on mine now...
Hey Mr. Joshua from Germany, I bet in the 7+ yrs since this thread was created, many many people have installed or tuned one of these kits for an Lsx car. I bet if you would just find your favorite search engine (vroom vroom) and type in "Ls1 STS turbo kit" or something along those lines, A LOT of info would come up from many different sites and people opinions, etc about these things. You would end up saving a lot of time and effort then digging up VERY old threads and posting a question in there when most of those members prob dont even come on here anymore.
Old Dec 31, 2010 | 04:51 PM
  #74
ZGOBYBY's Avatar
Thanks! It took so much work to really get it right, and I have to start working on the Z again in a couple of weeks here to get the thing running again. I don't really like when people cut out the whole center section on LT1 Camaros for their intercoolers, it looks weird to me.
Old Jan 20, 2011 | 03:56 PM
  #75
Yeah, i do alot of seaches... thats how i find these old threads lol. I look all over the place, trust me. I like diggin up old threads cause somtimes it shows the progress of their builds after so long. Shows wether they stuck to it or if they went another route. somtimes all it takes is an inquisitive soul to bring an old thread to life. Somtimes people just forget about it and later on, somone digs up an old one and has ALOT to contribute.
Old Jan 20, 2011 | 09:57 PM
  #76
20TA02's Avatar
its funny to see people argue that this kit did not work... 8 years later... they are still around and they do work...
Old Jan 21, 2011 | 01:53 AM
  #77
lol isnt it? Ive been keepong my eye on STS for a while andi always thought they looked cool and they were different. Just waiting on the tech to get better so that more info can be introduced on them, making them better.
Old Jan 21, 2011 | 09:26 PM
  #78
1CAMWNDR's Avatar
Really?? Do a search for the username Longrange4u. He is making over 1000 wheel hp with a rear mount turbo. The engineering is much better than what STS offers. Rear mount can be made to work very well, just not in a box from STS.
Old Jan 22, 2011 | 01:05 AM
  #79
Adam86's Avatar
This. I'm building a rear mount but about the only things I'm using from STS are the hot pipe, turbo, and wastegate. Modifying pretty much everything else about it from the piping to the oiling. Lots of downsides to the STS kits but they are definitely correctable.
Old Jan 22, 2011 | 09:50 AM
  #80
Oh I have been and what i ment that its nice to see that the forums are revealing the possibilities of a rear mount. Ive always like sts's for some reason.
