head gaskets???
Old May 6, 2009 | 09:17 PM
kenracer's Avatar
Default head gaskets???
What head gaskets to use on stock bottom end 6.0 turbo?
What holds up?
Old May 6, 2009 | 10:05 PM
WS6HUMMER's Avatar
What holds up?
I've researched it a little, have a pair of 317 heads that I want to run so I can run more boost also. From what I have gathered the majority of people run the GM MLS gaskets, very good and pretty cheap. I plan on running them myself.
Old May 6, 2009 | 10:11 PM
conan's Avatar
GM MLS or cometics. I havent had problems with my cometics but they are pricy. Get some head studs if you haven't yet.
Old May 6, 2009 | 10:13 PM
WS6HUMMER's Avatar
Did you stud yours? Can it be done with the engine in the car?
Old May 6, 2009 | 10:17 PM
conan's Avatar
Yes I studded mine when I built the engine and I have removed both heads in the car with no problems
Old May 6, 2009 | 10:22 PM
WS6HUMMER's Avatar
Cool, thanks.
Old May 6, 2009 | 10:31 PM
elias_799's Avatar
+1 for gm MLS gaskets. cheap and good
Old May 7, 2009 | 06:11 AM
Fireball's Avatar
the GM 5-layer MLS gaskets worked well for me last year...8.30s @ 170
Old May 7, 2009 | 06:28 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Unless you have o-ringed your heads, standard MLS will be fine
Old May 7, 2009 | 07:01 AM
Denali08's Avatar
Do u normaly o-ring the block or heads, or both?
Old May 7, 2009 | 08:30 AM
Fireball's Avatar
it varies with who you ask.
Some run no orings
Some run a single oring in the head
Some run with both the heads and block o-ringed
Old May 7, 2009 | 08:54 AM
HUNTER02SS's Avatar
I used standard MLS GM gaskets with o-ringed heads and they worked well.
The machine shop placed the o-ring in the groove on the gasket and it helped out tremendosly!
Old May 7, 2009 | 11:53 AM
pwrtrip75's Avatar
cheap felpro ones with a light coat of spray paint on them. They will never blow and you'll have to chisel them off to remove them. In a sense they are glued on. Cheap and very effective.
Old May 7, 2009 | 12:16 PM
Fireball's Avatar
thats a bold statement there....
Old May 7, 2009 | 12:18 PM
ls1290's Avatar
And sounds fairly half-assed.....
Old May 7, 2009 | 01:40 PM
HUNTER02SS's Avatar
Never Blow, Maybe, but I bet I can lift the heads and make them leak!
Old May 7, 2009 | 01:44 PM
Fireball's Avatar
run alot of boost + alot of timing + tr6 plugs (sorry veee8 ) and I guarantee they'll blow
Old May 7, 2009 | 01:59 PM
veee8's Avatar
LOL!!!! Yeah give me a crack at em', I bet they will be begging for mercy!
BTW my LS9's were sprayed with copper coat, and were glued to the block pretty well, in every spot except where I blew them with the aforementioned death cocktail.
Old May 7, 2009 | 02:03 PM
HUNTER02SS's Avatar
"Never Blow" is a term that I would not use in the racing world!
Everything is capable of blowing!
Old May 7, 2009 | 11:30 PM
kenracer's Avatar
Default GM head gsks.
Anyone have that part # for the GM mls head gsk for 2002 6.0?
"Never blow" sounds like what a exwife would say!
