Anybody making big boost power on L92 heads
#67
I sold my motor and ordered an AES short block: LSX block,410'' callies magnum crank and callies ultra billet rods with coated CP pistons and I bought a set of LSA heads which I just got back from WCCH they CNC'd them and installed the new valves I also went with the 1/2'' head studs so I had the heads opened up while they were there. I plan on making as much boost as I can with the F1R and expect to be north of the magic 1000hp this is all going in my 68 Camaro once the short block arrives I plan on starting a build thread. Frost will be tuning the car once it is up and running again should be interesting!!
#70
Richard from WCCH tells me the LSA program will flow the same as their L92 program. They cut 90% of the swirl wing out. I believe with the 1/2'' studs they will stay planted it is an experiment and if it does not work out I will replace them with the LSX L92 6 bolt heads seeing how I am married to my intake but I think they will take it they are a much cleaner casting of T6-356 and heavier than the L92 castings.
#74
i have also pushed stock l92s to 988rwhp without any water pushing on stock arp studs. i could of went more but ran out of injector that day.
#77
#78
Well "big power" has become a very relative term these days. 1000rwhp is no longer the big power it once was. 1500+rwhp certainly is though yet and i know of nobody making that kind of power on ANY stock casting head! There comes a level where you don't have a choice but to go with a .750" thick deck aftermarket casting.
#79
Can I get more info on this build?
Jeff
#80
http://www.youtube.com/watch?v=bjWwHPHxfi0
