going FIA need advise!
Old May 10, 2009 | 01:09 PM
solo21's Avatar
Default going FIA need advise!
I am about to go forced air, what is a good heads and cam for FIA? I have9/18 springs, are they good enough? I have ls6 heads now but are milled down to 59cc so I dont think its going to work and my cam is 226/230 @112 lsa from what Im told I need to go with 114 lsa and up....let me know what you guys got and made some sweet power....Thanks!!
Old May 10, 2009 | 07:24 PM
stevied916's Avatar
why f1a?
Old May 10, 2009 | 08:56 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
This on a stock shortblock???
Old May 10, 2009 | 09:02 PM
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
First question is: What are your power goals?
Old May 10, 2009 | 09:03 PM
kickassT/A's Avatar
couldn't tell if he meant f1a or forced induction something something, lol. with those questions i hope its not f1a
Old May 11, 2009 | 05:26 AM
NAVY's Avatar
Fms- f6-114
226"/230" .575"/.595" 114lsa
Old May 11, 2009 | 02:50 PM
solo21's Avatar
Sorry guys! I meant forced air induction, my goals are 650 to 700 hp so the f1a is a bit more than what I need...
Anyways what do you guys suggest on what cam and heads for Forced air, from what I have read it looks like 317 heads are pretty common
Old May 11, 2009 | 02:57 PM
ChevyChad's Avatar
yea, get some 317 heads at least. You definitely need to be closer to the 9.0~9.5:1 compression range. A D1SC will get you into that power range, but thats suicide to attempt it on a stock bottom end man...
Old May 11, 2009 | 04:37 PM
solo21's Avatar
yea i know, 650-700 is my goal but until I have the funds to build my bottom end I will keep the hp around 550 or so, I just wanted to know what head and cam package to go with, that way when I build my bottom end my setup will be ready for it.....what is a good cam for my goals?
Old May 11, 2009 | 05:08 PM
allthrotle's Avatar
Dude i would hold off on buying the heads if you plan on running the stock bottom end at that power level. If you blow your motor you take the chance of taking the cylinder heads out with it.
Old May 11, 2009 | 07:16 PM
A d1sc would be better suited for this task.
Old May 11, 2009 | 07:52 PM
solo21's Avatar
I am talking about the d1 procharger.....I thought as long as I kept the boost around 8lbs I would be ok, that's what I was told from a couple guys on here...
Old May 11, 2009 | 08:41 PM
ChevyChad's Avatar
For a stock bottom end, I'd recommend a set of stock 317 or 035 heads (same thing), a double spring like patriot golds with hardened pushrods, and a comp SC2 cam from speed inc, or the blower cam EPP sells. Those combined with a D1 kit with the larger filter EPP sells and a good exhaust with headers should get you in the 500~550 range with a conservative tune at ~8psi. Don't get greedy with the boost. You may make the number you want with a lower boost# if you have a good exhaust. The stock pistons are good for a certain amount of HP, not any certain amount of boost pressure, so keep that in mind.
Old May 11, 2009 | 08:53 PM
solo21's Avatar
That's the answer I was looking for! Thanks guys for helping out,and sorry for the confusion at the beginning od the thread, I will call epp and see what bob can do for me, I have talked with him before he's a cool dude... Thanks man!
Old May 11, 2009 | 08:59 PM
ChevyChad's Avatar
Good luck yea, Bob is a great guy to do business with Oh, and while you are at it, head studs would be a good investment
Old May 11, 2009 | 09:32 PM
stevied916's Avatar
I'm going to run the stock heads and stock long block, ls6 springs and 60's with 110k on the d1, 4.5" pulley and fmic. I wouldnt recommend it but I don't feel like changing them at the moment. It should be fine with low timing and meth. I will switch to e85 once I get a second pump
