for all you high hp guys
Old May 10, 2009 | 07:43 PM
Shawn @ VA Speed's Avatar
Default for all you high hp guys
https://ls1tech.com/forums/new-produ...rt-system.html
Old May 10, 2009 | 10:13 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Do you still dowel the main caps with the support system? Is that included in the price? When ever I get ready to put the engine together for my 93 I will more than likely be making a road trip to visist you guys.
Old May 10, 2009 | 10:42 PM
NA$TY-TA's Avatar
Ive sen it in person. Its a bad piece for sure
Old May 11, 2009 | 04:18 AM
ohplz's Avatar
what would u call high hp?
Old May 11, 2009 | 05:50 AM
Fireball's Avatar
Me too...very well engineered piece with how it interfaces/interlocks with the block...
Old May 11, 2009 | 06:17 AM
ohplz's Avatar
http://www.dmperformance.org/
they do a fully engineered engine girdle....
whats the diff with yours?
Old May 11, 2009 | 06:39 AM
I originally designed the support for the lsx block,they have the caps doweled already,but the stock blocks should be doweled-I'll do this for an extra $100.00 considering it's only a little bit more machine time.
alot-my support has a mechanical lock into each cap as well as into the oil pan rails of the block,this ensures absolutely no movement in the main caps,whereas the others rely on friction to hold the caps in place-it doesn't work on the bottom-why would it work on the top?
Old May 11, 2009 | 07:27 AM
ohplz's Avatar
fair comment, the only reason i asked is i was put onto that website for a girdle.... but then i saw yours? so was curious, i was about to buy the other one...
again what do u call HIGH HP?
Old May 11, 2009 | 07:43 AM
Fireball's Avatar
Shawn didn't put one on my 1500 hp setup, though I'd probably start thinking about using one at that power level...
Old May 11, 2009 | 08:42 AM
there are alot of factors you need to consider-hp,rpm,stroke,weight of rotating asy,crankshaft design.all of these play a factor into main cap loading and whether or not you should run one.but as a general rule i would say 1200hp with steel rods and 1500hp with alum rods-but there will be 100 guys that will argue that
Old May 11, 2009 | 08:57 AM
Big_Bird_WS6's Avatar
sorry but your comment with the DM peformance peice needs said again. cause i got the DM girdle and it is great. and my billet main caps are dowel pinned. and i ahve all that for far less then $1400 + $100 for dowel.
so why would someone run yours if all it helps is bottom of main caps? i mean i got close to $600 in mine. that is dowel, girdle, and arp studs.
so if i built another motor. why run yours over DM? just $900 is big difference
Old May 11, 2009 | 09:14 AM
Phil99vette's Avatar
7 Second Club
One thing that Shawns main girdle does is "keys" the bottom of the motor together. The Billet tool steel key'd into the oil pan rails and the main caps keeps everything from moving. The DM performance is a nice girdle for a low HP setup but its been proven that you don't need a gircan do without1000hp. After seeing how the main webbing and lower end of the motor is moving at high HP levels, the DM just wouldn't have gotten it done.
So as to your cost of the DM, the plate is 389, studs are close to 200. How much did you pay for your dowel pinning and the line hone? Most shops charge $150 for the pinning and $100-$150 for the line hone.
Old May 11, 2009 | 10:33 AM
Denali08's Avatar
The support system with all block machining,including line boring and main stud set will sell for $1400.00.
How much for parts only, less machining, for in-house installers?
Old May 11, 2009 | 10:53 AM
pm me to know cost. sorry not just going to give that out.
second.how is dm for low horse?
katach recommends it for high horse. 750 plus.
and the dm is on a ronnie duke (i dont know who that is. it is on the site) 1500+ horse motor. so how "wouldnt have gotten it done"
Old May 11, 2009 | 10:57 AM
ls1greg's Avatar
So this sits between the block and the oil pan? How much lower will the oil pan now sit? How will this lower oil pan affect my ability to bolt my bell housing to it? What about the oil pickup in relation to the oil pump? Wouldn't that be lower too now? Maybe 1200+ HP guys don't even use that stuff, making it a non-issue...
Old May 11, 2009 | 10:59 AM
Fireball's Avatar
1500 isn't alot of horsepower anymore....at 2K+ hp, the builder should be doing what they can to be sure stuff don't move...not hope stuff won't move. trying to save a few hundred dollars at that level will cost ALOT more when it lets go...
Old May 11, 2009 | 11:12 AM
fireball. thanks for your help. but i would like to here this from shawn. they made it.
i wasnt saying that 1500 was a lot. or that 1500 isnt a lot. and i undersatnd going cheap is not the right way. but my question is WHY spend the extra $900. if i get the same stuff from $600. and the line hone is used in both girdles. so i didnt include that. so if i include it in mine say 150. then add 150 to his. back to zero.
the ops of my caps dont move cuase of dowel pin. the bottom is tied into girdle which is tied to each other. why tie it to blcok? and like ls1greg said. how does this mess up oil pan? or pump pick up? or bell housing? idk how thick there piece is, but even if it is paper thick it will make a difference. and on top of changing studs to be longer. i also need longer oil pan bolts.
to me(this is my opinion) that is is 1400 + 100 for dowel + 50 for new oil pan bolts + say 150 for redo bell housing + 150 for line hone. well that is like 1850. or spend 389 plate + 200 studs + 150 line hone + 100 for dowel. well that is 839.
i mean $1000 difference if it just hold the main caps from moving?
so shawn. why would someone buy yours over DM? i have a nother build starting and it will be a high horse. so i would like to know which way i am going on this one.
thanks
Old May 11, 2009 | 11:22 AM
Fireball's Avatar
I know I'm not shawn...but I am a mechanical engineer so I know a little about this
tieing to the block distributes the load over a larger area...the whole block can move around...not just the main caps...the idea is to support the entire bottom end...
won't mess the oil pan since it only moves down a little bit...for wetsump, the pickup could be tweaked the additional difference to ensure proper oil scavanging...for drysump, makes no difference
how would the bellhousing be affected? it bolts to the block...something at this power level won't be using a T-56 or 4L60E or a stock oil pan for that matter...so those bottom two bolt holes are irrelevant
Old May 11, 2009 | 11:26 AM
ok. i see.
well why wont it the t-56 do it? vipers have 1500 horse t-56? do those bottom holes matter.
like on my tr6060 build do i need to use the bottom two holes?
Old May 11, 2009 | 11:30 AM
Fireball's Avatar
ok. i see.
if you go drysump or aftermarket wet sump...those bolt holes are gone.
the transmission alignment dowels do most of the work, the bolts just keep the mating surfaces secure.
