Do certain turbos make more sound then others!
#41
Not us, who are currently in it.
#42
here are my twin 76's, no boost though... Car was not tuned. But you can still hear them pretty good.
http://www.youtube.com/watch?v=nT1XxCcKdUE
The following users liked this post:
Transamthunder (04-19-2020)
#44
Not really digging the exhaust. nm read post
old run- not to redline - the turbo is alot louder than it sounds in the vid
http://www.fquick.com/videos/viewvideo.php?id=887
#46
My tc 78 has a sweet spot at part throttle that is LOUD. People will stop & look, it sounds cool to me. But it goes away as I starting building boost or maybe the engine noise drowns it out.
#47
Ive read this whole thread and i think people are getting confused.
It seems that people are refering the "TURBO WHISTLE" to either
A: the whistle that the turbo Compresser wheel makes under extreme rpms (boost)
or
B: the whistle of the Exhaust wheel chopping the air up as the exhaust gases exit, (mostly open down pipe)
the original poster i believe was refering to A.
or
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#48
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
x2
depends where you stand to listern ..
if you stand , down the track at the deep end, you will here a jet like noise, not much engine noise,
sounds horny.....
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
the high pitched noice is the compressor wheel grabbing the air, at high speed.
stand behind the car, as it drives away....
sounds more like a muffled v8 noise, also you get a 'different' sort of whisle noise...
the 2 step car be heeard better behind the car , on the start line.
the best spot i believe , it in the deep end , @ about 1000 foot mark, with the turbo car on a solo run, so you can hear it coming, then as it goes pass @ speed you will hear the exhaust noise under FULL load...
#49
Ya know, I find my turbo's to be weird. I really don't even notice them a whole lot when I am WOT to be honest. Currently my car is dumps so I heard mostly engine notes. II did hear some rush of air from the dual TiAL 50mm bovs. I also run two 44mm TiAL open wastegates now as well(in this video I am going to link, it has turbosmart open 38mm gates. I never noticed soo much the sound of the spool but,..heres a video of it if you wanna check it out.
![](http://i70.photobucket.com/albums/i86/V-seriesTech/th_chaos_dyno.jpg)
Also, I noticed, sometimes, at idle, or low rpm speeds, the turbos have a whirl or a howl to them. This sound is not always there,...which is why there odd to me. Don't know if its a temp thing but,...it's either so quiet you don't know it's there,...or its loud enough to where I'll pull into spots and I hear people saying "he must still be runnning the procharger" . WHich...it's not blower whistle loud,...but similar. It sounds kinda wicked.
If you listen at the very beginning of the video...you can hear what I am talking about very well. Also on my return,...you'll hear it well too. Check it out if you got a minute
http://www.youtube.com/watch?v=kaWyNBMIsSE
#50
10.5 year bump....
My 7875 from VS currently on my K5 doesn't make any cool turbinski sounds while spooling. It used to have a S475 that would sound like a jet before it was making a single pound of boost. Hopefully the eBay GT45 going in my squarebody crew cab dually LS swap will make more noise.
#51
10.5 year bump....
