problem solving at 1100 rwhp (help )
Old May 13, 2009 | 06:24 AM
Denali08's Avatar
Originally Posted by hawkls7
Problem resolved , various minor ajustments made 3 consecutive runs with great results thanks to all your input.
Minor adjustments of what?
Don't fly without telling us.
Old May 13, 2009 | 07:58 PM
blacksi's Avatar
He'll probably have to ask his tuner.
Old May 14, 2009 | 12:54 AM
hawkls7's Avatar
There were several things we changed , new crank sensor , heat shields on coils,smaller gap on plugs, insulating the spark leads ,earthing the engine more,re ajusting the afr , minor things but a pain to resolve after many runs .Here is the graph. Im very pleased with the outcome , the power is enough for my weekender
Attached Thumbnails problem solving at 1100 rwhp (help )-tony-27s-20blackhawk-201100.jpg
Old May 14, 2009 | 01:10 AM
Adam98Z's Avatar
Good gosh! Better be enough for a weekender! Very nice. Glad you got it all worked out.
Old May 14, 2009 | 02:38 AM
LilJayV10's Avatar
What is earthing the engine more? I have never heard that before.
Congrats on your setup.
Old May 14, 2009 | 03:36 AM
Inspector12's Avatar
TT-TECH Veteran
Grounding.
Old May 14, 2009 | 06:02 AM
stevieturbo's Avatar
The Jap cars seem very fond of earthing the crap out of theirs. Using large diameter cable, earthing various points on head and block, all linking back to a single point either on battery orchassis ( or I guess a similar solid earth point if battery is located in the trunk.
Similar in style to a shielding cable....all earths run to one location, to help reduce any interference.
My battery is in the trunk and grounded there to the chassis, but also with a cable running to the front, which then links to the engine block, chassis, ecu, and coils+heads
All interlinked with decent sized cable ( not sure what awg it is...but capable of circa 40-50A, 6.0mm^2 )
Nice results Tony...also interesting to see that running leaner on the AFR's doesnt seem to gain much in power.
Might be interesting to try in the 10's also ?
Old May 14, 2009 | 07:26 AM
veee8's Avatar
I wonder what the dip is above 5700 rpm.
Old May 14, 2009 | 07:31 AM
Big_Bird_WS6's Avatar
hey can someone talk about this 16V thing more? when do you get to this point? and what will it do to all the gauges and fuel pump and ****? does all that need changed to hold the volt load?
Old May 14, 2009 | 08:33 AM
hymey's Avatar
power dip at 5700? Maybe wheelspin at top of peak torque. Did you increase your dwell. I run TR6 with my T trim setup run .35thou gaps and 3.8ms dwell time up top.
Keep it rich under boost doesn't make a difference by the looks of things to power just lots safer.
Awesome power dude on a digital Dyno Dynamics to well done. Keep it rich under boost doesn't make a difference by the looks of things to power just lots safer. Is it MAF or SD 3 bar?
Old May 14, 2009 | 08:38 AM
hawkls7's Avatar
It could be wheel spin
Old May 14, 2009 | 08:45 AM
  #32
hawkls7's Avatar
3bar .It has taken several days in getting this far , we can still i think get a little more but my original goal was for 1000 im happy with this outcome . this is a street car if it was a drag car it would be set up differently like twin turbos and custom manifold and so on
Old May 14, 2009 | 08:47 AM
  #33
hawkls7's Avatar
Hi steve , one thing we did do was run an earth from the engine to the battery in the boot which could of fixed my prob.
Old May 14, 2009 | 08:55 AM
  #34
HUNTER02SS's Avatar
Grounding your batter to the block is very important on EFI car's. If not the EFI computer will try to find a ground through other source's and usually cause's the computer not to work properly.
Old May 14, 2009 | 03:02 PM
  #35
ftorsell's Avatar
how meny cui is this engine?
Old May 14, 2009 | 04:34 PM
  #36
99Ls1fever's Avatar
Originally Posted by 98Camarod
What exactly was it then?
Plus 1, Agreed need to know after reading thread.
Old May 14, 2009 | 05:12 PM
  #37
HUNTER02SS's Avatar
Sounds like this was more of a grounding issue.
Old May 14, 2009 | 11:08 PM
  #38
hawkls7's Avatar
We did play with the dwell settings, we also had better results with the tighter plug gap and an 8 ngk heat range non projected.we are going to 16 tho, which is indicating something with spark, seems to shop best results
Old May 15, 2009 | 04:07 AM
  #39
Are you using NGK racing plugs, or just cheapy ones ?
Old May 17, 2009 | 06:22 AM
  #40
hawkls7's Avatar
we have tried allsorts that ngk have to offer but best results are the ngk b8efs which is non projected but no v grove. i think it does not matter , as long as you can read your plugs and selecting the best heat rating is the important part.
