intake and cam?
Old May 12, 2009 | 12:40 PM
iMpoSStoR's Avatar
Default intake and cam?
need your thoughts on which intake works best for boost.. got a 6.0 with afr heads and going with a procharger (gonna run anywhere from 10-15 psi) and thinking of going with fm9 cam.. any info will be great. thanx.
Old May 12, 2009 | 01:02 PM
TT402LS1's Avatar
I personally like the Carb. style intakes for boost. It evenly feeds each cylinder. (or better than the factory styles one do) I know this has been debated to death, but this is my opinion.
Ron
Old May 12, 2009 | 01:36 PM
ls1290's Avatar
Dumb Ass Vette Moderator
I have switched from a LS2 to a Vic Jr. Doing this has drastically helped out the idle characteristics. It also resulted in about 30 rwtq loss to about 4500 RPMs, but it has also picked up 25ish rwhp in the upper RPM range. The 5700 to 6800 RPM range should be finished today or tomorrow Well worth the switch IMO.
Old May 12, 2009 | 07:47 PM
mike13's Avatar
what about intake and cam for boosted 346 3200-6200rpm? Also how many carb type intakes are out there?
Old May 12, 2009 | 09:58 PM
iMpoSStoR's Avatar
347 was my second option.. lol.. that i know of there is the vic jr. and the super victor... what do ya'll think of the new pro-flo xt?.. we've installed a couple of them but on nitrous fed motors.. lost a couple of ponies N/A (18hp at most) but gained that and alot more on spray. (this was on trucks though..truck scene is huge here in south texas)
any thoughts on the futral fm9 cam?..
Old May 12, 2009 | 11:47 PM
Bird-Of-Prey's Avatar
Interesting? I would have thought a loss in the torque department down low but not in horsepower.
Old May 13, 2009 | 12:19 AM
iMpoSStoR's Avatar
should of been a lil more specific... the truck had a ported fast 90/90 setup... tomorrow.. well later today actually i'll check the dyno database and see exact numbers before and after..
any good s/c cam recommendations?
Old May 13, 2009 | 05:03 AM
EPP's Avatar
EPP
http://www.exoticperformanceplus.com....html?item=679 Link to our blower camshaft
LS2/402, off the shelf AFR 225 heads, LS2 intake, EPP cam, ProCharger F-1A.
We have had great success with the above camshaft in a lot of different vehicles. Bob
