Question for all fabricators...
Old May 15, 2009 | 03:59 PM
bigbird01's Avatar
Default Question for all fabricators...
How many of you do it yourselfers or sponsors have used a mig welder for their stainless steel turbo build? How has it held up? Would it make a difference if it had solid motor mounts and the turbo was fixed also to help with cracking? How did it turn out for you guys? what gauge did you guys use also? Do any of you guys see a reason not using a mig for this kind of build? Im thinking about picking up a welder and learning before I take on the task of sideways240 even though his turned out really good I dont trust myself that much. Thanks in advance.
Old May 16, 2009 | 12:24 AM
Josh@KY-Turbo's Avatar
You can MIG stainless if you want to spend the $$$ on Tri Mix Gas ans stainless wire. I TIG everything.
Old May 16, 2009 | 06:52 AM
98Camarod's Avatar
Any info on your tig setup by chance?
Old May 16, 2009 | 08:42 AM
73 nova guy's Avatar
I just picked up the new miller 165 dimersion. It's a nice little ac/dc tig for 1400 bills.
Old May 16, 2009 | 12:55 PM
Sideways240sx's Avatar
Take your time, dont have deadlines for your car. read as much info as you can. Worst case scenario you get all your bends made up, tack them in places, and bring them somwhere to get welded nice.
Not all my welds look the greatest, it was our first attempt at anything like this.
If i were to do it again, which i will sooner then later, it will be better.
Good luck, Chris
Old May 16, 2009 | 01:11 PM
Big_Bird_WS6's Avatar
i mig all stainless. 8 hours a day. 6 days a week. it will hold up and you dont need tri mix.
tig is great but slow. get a good pulse miller mig setup and you will never tig again.
my pulse welder has replaced my tig basicly. i do black, chromoly, stainless, aluminum. it love the ****.
Old May 17, 2009 | 09:26 AM
crf538's Avatar
great welder for the price, i used to use the mig welder but now that i have access to a tig thats all i ever use. The tig is really great for stainless.
Old May 18, 2009 | 02:46 PM
PlatnumStatuz's Avatar
I have a Millier Synchrowave 250. I'm slower with it than on our mig but I like the tig better
Old May 18, 2009 | 03:38 PM
stevieturbo's Avatar
TIG looks nice.
MIG works. As I said elsewhere, just look at most mass produced stainless exhausts or mufflers. ( eg Magnaflow ) they are all MIG welded.
I also find that with MIG....there is much less chance of weld protrusion inside the pipework. Although thats maybe just because I'm ***** with a TIG.
Old May 18, 2009 | 10:32 PM
I have a Miller Syncrowave 200.
Old May 18, 2009 | 11:36 PM
i like pretty welds
Old May 19, 2009 | 04:55 AM
Pretty welds arent always stronger welds though. But they do look good.
Old May 19, 2009 | 12:33 PM
pwrtrip75's Avatar
MIG/TIG are just processes. Either or can be weak and both can be equally strong. And both can look really good. MIG welding is more for production (higher paced) work, TIG welding is for the artist if that makes sense. But if you know how to use both then strength wise there is no difference in the welds each create. Delecate work that you want zero spatter on also use TIG. You'll usually get more heat into your peice when you TIG (because your slower and more precise), so you need to account for that, warpage, shrinkage....etc.
Old May 19, 2009 | 02:06 PM
Phil99vette's Avatar
7 Second Club
Miller Dynasty 200 Tig and Millermatic 180 Mig are my weapons of choice.
Old May 19, 2009 | 05:06 PM
WS6HUMMER's Avatar
I tigged all my 304 stainless hotside with a DC Lincoln stick machine I already had, just bought a nice used weldcraft torch off e-bay for 75.00 You just dont have the luxury of a pedal and you have to scratch start which in my opinion makes you learn to be a better welder.
Old May 19, 2009 | 08:14 PM
MIGHTYMOUSE's Avatar
main thing is dont worry about getting it right the first time, or even second
ive got scraps welded to crap welded to stainless welded to aluminized blah blah get a decent welder and a clean surface w/ a good ground and you can pretty much make anything stick and last a couple years.
get some of that fiberglass wrap and just worry about covering it all up with a neat job of that!
Old May 19, 2009 | 08:25 PM
that's the suck part. all that art and wrap them in fiberglass.. its sad but must be done!
