turbo cam
Old May 17, 2009 | 11:39 PM
6.0mustang's Avatar
Default turbo cam
who makes good turbo cams?
Old May 18, 2009 | 01:16 AM
shawn_c992001's Avatar
EPP. Where are you Bob?
Old May 18, 2009 | 05:39 AM
Fireball's Avatar
shawn @ va speed can spec out a nice turbo cam too...he spec'ed mine
Old May 19, 2009 | 06:34 PM
6.0mustang's Avatar
does a ls6 cam make a good turbo cam? i'm going to use it regardless, until i can afford a good cam. but with 117.5 lobe seperation. sounds like good turbo cam.
Old May 19, 2009 | 08:26 PM
nastychevelle's Avatar
the ls6 cams are great for boost just a little on the small side..........
Old May 19, 2009 | 11:37 PM
droksformula's Avatar
Speed inc. makes a couple different ones to beest match your setup.
Old May 21, 2009 | 03:21 AM
TransAmcoupe98's Avatar
The Z06 cams are awesome for boost. 2001 Z06 cams are a bit smaller so look for a 02-04 z06 cam. You can always get a good off the shelf cam. An LSA of 116 and higher will be good. Anything lower than 116 IMO is bad news due to bleed off. I ran into the same issue with my Turbo T/a. it was a 222/224 with a 112 lsa. Picked up good down low but never saw al the boost.
Old May 21, 2009 | 09:15 PM
Josh@PremierAutosports's Avatar
There is so much miss information on here about turbo cams. Boost makes so much decent stuff look great. I feel a c5z06 cam would work good with stock heads on low boost. A good turbo cam depends on your setup and power goals. If you have a stock 5.3 yes a ls6 cam would work good. If you have a c5r head 427 it would suck. What are you looking for out of your build?
Old May 22, 2009 | 12:39 PM
engineermike's Avatar
Originally Posted by b18c1hybrid
there is so much miss information on here about turbo cams.
x 4584098409408943723485834507
Old May 22, 2009 | 08:40 PM
EPP's Avatar
EPP
lol, we initially tried the spec's of our forced induction camshaft on a 2002 Z006 that we built using an HP turbo twin turbo kit. Here is a link to this car. http://www.exoticperformanceplus.com...Car.php?car=26 The owner wanted a camshaft with a 60's sounding idle. It worked out great and we have used it on other turbo cars and many cars and trucks with ProChargers and Maggies. Here is a link to this Z06 on the dyno and on the highway. http://video.google.com/url?docid=30...HCAO9kkY_gce6w
Link to our camshaft. http://www.exoticperformanceplus.com....html?item=679 Bob
Old May 24, 2009 | 11:57 AM
Texas Heat's Avatar
Im running a LS7 cam in my setup and it loves the boost.
