Question on sheet metal intake manifolds
Old May 18, 2009 | 03:22 PM
black98ws6ta's Avatar
Default Question on sheet metal intake manifolds
I am thinking of fabricating one for a 03 cobra and was wondering if there are rules of thumb for runner length or plenum volume? In all honesty the only reason I am going this direction with the intake is to showcase some of my fabrication and to have a nice looking manifold. I dont know very much about how the options affect the performance. Here is one I saw on Mod Fords and I dont even really like the look/design.
Old May 18, 2009 | 03:38 PM
cracker's Avatar
This one is for sale. Works forward or rearward facing. Let me know.
Old May 18, 2009 | 04:21 PM
Mavmavv's Avatar
Runner length will move the usable rpm range around of any engine. Longer runners = more tq down low. Shorter runners are for higher RPM applications.
Things that also need to be taken into consideration are the size of the motor. Im not positive, but im pretty sure thats the gist of it.
Old May 18, 2009 | 06:19 PM
98Z28CobraKiller's Avatar
Restricted User
If it's for an FI application, all you need are 2 flanges, 8 4" runners and a plenum box with a flange for a throttle body.
Old May 18, 2009 | 06:35 PM
I didn't know if something like this would work for the plenum or if it was too small? Most v8's seems to have more plenum volume.
Old May 18, 2009 | 07:01 PM
elias_799's Avatar
i would not mess around with building an intake manifold if it is your first time, especially on an expensive car like that. you can make some of the cylinders run lean and burn your piston rings.
Old May 18, 2009 | 08:33 PM
Shawn @ VA Speed's Avatar
x100000 airflow distribution is the most important part of manifold design.it is also the most overlooked
Old May 18, 2009 | 10:33 PM
elias_799's Avatar
yea and that's why the sheet metal manifolds that are made correctly go for allot of money, not just because they look good.
Old May 18, 2009 | 11:21 PM
Most of the manifolds look very simple to me...they all have a plenum and equal length runners. It does not appear that the few posted in this thread have anything special for airflow or distribution? I am looking for facts on the subject.
I am confident I can build replica's of all the peices I have came across so far(as far as funtionality goes, maybe not 100% on the workmanship, lol)
