Anyone tack welding reluctor wheels????
Old May 22, 2009 | 07:37 AM
veee8's Avatar
Default Anyone tack welding reluctor wheels????
Is it good insurance to tack the wheel to the crank flange on a boosted motor? How large/many tacks are used? How much heat needed on welder (TIG)?
Old May 22, 2009 | 08:02 AM
ABeasst's Avatar
my motor builder has always tacked my reluctor wheel.
Old May 22, 2009 | 08:05 AM
Phil99vette's Avatar
7 Second Club
Yes, I tig welded a 1/4" section on both throws.
Old May 22, 2009 | 08:20 AM
veee8's Avatar
How much heat did you use Phil?
Old May 22, 2009 | 08:43 AM
7 Second Club
Good question, I did it soo long ago I really don't recall. I'd have to say 80-125 with a pedal not maxed out.
Old May 22, 2009 | 09:10 AM
veee8's Avatar
Yeah I figured around 100.
Old May 22, 2009 | 11:50 PM
Louis's Avatar
Yep, 2 beads, about an inch long. Make sure you check the run out afterwards.
Heat is 125, I use .035 stainless rod.
Old May 23, 2009 | 09:53 PM
Denali08's Avatar
Anyone got a picture of the welds?
What's the reason for welding?
What could go wrong without it?
Old May 23, 2009 | 10:46 PM
Gordon0652's Avatar
+1
Old May 24, 2009 | 12:49 PM
Louis's Avatar
The reluctor has the potential to spin on the crank. Ask PSJ how his reluctor was on his ARE 422
Old Jun 9, 2009 | 04:21 PM
Louis's Avatar
bumpity bump for Veeeeeee8
Old Jun 9, 2009 | 04:30 PM
veee8's Avatar
Thank you sir, that is exactly what I was looking for.
Old Jun 9, 2009 | 04:35 PM
Shawn @ VA Speed's Avatar
make sure you get you rotating asy balanced first-sometimes you have to add a slug of mallory on the rear counterweight and have to take off the reluctor wheel in order to do that
Old Jun 9, 2009 | 05:31 PM
Louis's Avatar
and watch the warpage on the reluctor...
Old Jun 9, 2009 | 05:34 PM
Fireball's Avatar
you have the workaround for that though
Old Jun 9, 2009 | 06:54 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
You are taking the weight of the reluctor into account of the rotating assembly aren't you?
Old Jun 9, 2009 | 07:41 PM
allthrotle's Avatar
If you have your rotating assembly balanced first and then you tach weld the reluctor ring would you have to re-balance the assembly?
Old Jun 9, 2009 | 08:11 PM
i didn't say take the reluctor wheel off-just wait to weld until you get rough balanced
Old Jun 9, 2009 | 08:42 PM
OWN3D BY MY PROF!
^ I understand. You wouldn't want to weld the reluctor and have to add metal that would require the reluctor wheel to be removed.
