Which new turbo should I go with?
It sounded like change clanking around if that makes any sense. Well, I talked to them the other day and a bolt actually went through the exhaust somehow and chewed up the impeller on my gts76!! I have no idea how it got there but I have to basically replace or rebuild the turbo so I'm wondering what everyone thinks I should go with. Here's my mods:Engine Iron block 408Callies Magnum crank
Compstar rods
Diamond pistons
Total seal rings
TEA stage 2 LS1 heads
Camshaft..232/240@ .050 595/608 lift 115 LSA
Fast 90/NW 90 intake
SLP LT's
LS6 oil pump
Chevrolet Performance valve covers & coil relocation brackets
Fuel system $$
Aeromotive 11104 pump
Aeromotive fuel regulator
Aeromotive fuel rails
Aeromotive fuel pump controller
Steel braided lines
Earls fittings
Power adder
76 GTS rearmount turbo...started out as a STS system, EPP completly reworked most all of the orginal STS.
Big FMIC
Drive train & suspension
RPM 4l60E transmission
Vigilante 3200 TQ
3" steel drive shaft
Spohn adj. torque arm..chassis mounted
Bmr dbl adj control arms
Lake wood adj. panhard rod
Relocation brackets for control arms
Stock springs
KYB shocks and struts
Moser 12 bolt with 33 spline axle's...3:73 gears
Eaton
Any input is appriciated, I've been told that I could go with a bigger turbo and I guess now would be the time to upgrade
So post away!!Ryan
I'd go with whatever Larry and the guys at Speed Inc recommend. If they think you can step it up to an 80 or 88 I'd say go for it. You might have a little more lag with the bigger turbo but I don't think it will be noticeable with a good tune. Zombie is running an SX80 I believe. You could also pm Zombie to see what he thinks would work best with your setup. Whatever you do just don't sell it. Trending Topics
Ryan
A t76 will get you around 650 rwhp on a 408, turbo is just too small. Even the 80mm I'm running probably won't get you past the 800 rwhp mark. For a 408 you really need an 88mm turbo.
That is one of our T6 GT88's. Car is sick...Mike and Cartek has done a killer job on it.
What brand 88 do you reccommend and what kinda $$ are we talkin here. And do I have to upgrade anything else besides the turbo itself?
Thanks again,
Ryan
