fastest on a stock pcm?
Old May 29, 2009 | 04:55 PM
05crew's Avatar
Default fastest on a stock pcm?
is there anybody using a stock pcm and running a 8sec pass? or do i have to run a big stuff or fast computer?
Old May 29, 2009 | 04:57 PM
98Z28CobraKiller's Avatar
Restricted User
Stock PCM is good to 3 bar and 8K RPM.
Old May 30, 2009 | 04:16 AM
black98ws6ta's Avatar
There are several cars going that fast on stock pcm. Mine being one of them. The standalones do have some advantages at that power level.
Old May 30, 2009 | 02:30 PM
vladss's Avatar
what are the limits of the Factory computer?
Old May 30, 2009 | 02:48 PM
You always have to buy z injectors and a 2 step, things that are included in most standalones.
Old May 31, 2009 | 06:18 AM
cjg454ss's Avatar
the new 80lb injectors work and are 93 lbs at 58psi. i just got mine. another guy here made mid 900 rwhp at 80%injector duty with them.
Old May 31, 2009 | 12:17 PM
I'm sure that you can run in the 8's on stock pcm and high impedance injectors...but there will be way more potential with a box and whatever injectors you want to run.
Old May 31, 2009 | 05:38 PM
cjg454ss's Avatar
yeap went 6.25 at 116.97 on 15psi. 80% duty. 1.53 60 ft didnt help
