Help! it cranks but won't start.
. I'd really appreciate any help as to what could cause this. Thanks! Cam sensor won't stop the car from starting.It will start harder sometimes you have to turn key off then crank and repeat multiple times but car will start and run.
You can check easily for spark.hold plug against engine when cranking. You can check for fuel. Crank sensor will stop car from starting . Ok you said no fuel and no spark.
Are all injector and fuel related fuses ok. What pump setup..home made? Can't help you if its homemade setup. You have make sure your pumps are working. I went lonnies twin pumps,prewired and plug and play.Test your pumps if you can. Into a bucket.
Car should fire if you have fuel and spark. And crank sensor is plugged in and working.
for spark check main injector harnesses are plugged in and all related fuses are fine.
Engines are simple really give them fuel and spark and they run basically.
Are you getting any codes..you would likely get codes for crank sensor. I am betting you just aren't getting fuel to the injectors.But of course you need spark as well.
, I'm leaving tonight and will be out of town for the rest of the week, that's why I was really dissapointed and so bumed-out that I couldn't get it running before I leave, but thanks for all your responses, they atleast gave me some hope and somewhat narrowed it down as to where to start when I get back. Thanks, again! Last edited by Boo"SS"t; May 31, 2009 at 06:36 PM.
. Keep us posted. I had cam sensor problem that drove me crazy. Changed out sensor like three times. No way to bench test the cam sensor. Finally figured out how to check them in car with the car cranking intake still off. But every time had power to the sensor connector ,but sensor was intermittent. Turned out female connector was not grabbing pin tight. Had hard time plugging in the cam sensor when did my 408 swap. So it must have got opened a bit too much and intermittent drove me nuts. Cam sensor codes, car was hard to start, tach was dead as doornail well usually sometimes it was working.Finally took connector apart and tightened it up and no problems since.
So really you likely need a meter and start checking power here and there.
