F1R 427 C6...numbers
Old 08-21-2009, 01:54 AM
  #61
blk00ss's Avatar
Is this on pump gas?
Old 08-21-2009, 07:28 AM
  #62
Mr.Big's Avatar
+methanol injection...
Old 08-29-2009, 12:50 AM
  #63
john_sblendorio's Avatar
Originally Posted by hawkls7
well done, can you show pic off belt set up
This is the closest pic I have.
Old 08-29-2009, 01:29 AM
  #64
one fast zo6's Avatar
very nice work!
Old 08-29-2009, 01:18 PM
  #65
gnx7's Avatar
put some VHT on the belt and I bet you find that missing boost....
Old 08-29-2009, 01:26 PM
  #66
Restricted User
98Z28CobraKiller's Avatar
......and the engine compartment will look like the inside of a cotton candy machine. LOL
Old 08-29-2009, 01:30 PM
  #67
03supercobra's Avatar
Hahaha so true, so true.
Old 09-01-2009, 04:14 PM
  #68
ftorsell's Avatar
Smile
Originally Posted by john_sblendorio
After a long anticipated wait, we should be hitting the dyno this week. Previous build
HKE 427
ProCharger F1C
As cast LS2 heads
Stock LS2 intake
Dallas Performance fuel system
Dallas Performance Big Mouth inlet
Dallas Performance custom IC plumbing
8-rib pulley system
ECS dual nozzle Alky
RPM 3.42 diff
853rwhp/744rwtq @ 16# - MAF and injector limited
New build
ETP LS7 4.1 heads
DP ported GMPP LS7
Jesel rockers
Morel's
4" intake plumbing w/ integrated MAF
DP 10-rib system
ProCharger F1R
what engine block components are you using i havent heard about hke 427
i understand its 427 cui but what brand is the engine block?
regards fredrik
Old 09-01-2009, 07:00 PM
  #69
regards fredrik
It is a Race Engine Development (R.E.D.) prepped, Darton sleeved LS2 block. HKE is based in Houston and is a LS1Tech sponsor. Erik is considered amongst the top engine builders in the country and he goes by racer7088. If you are considering a new build, you really need to put them on the short list. http://www.hkracingengines.com
Old 09-01-2009, 10:16 PM
  #70
TT-TECH Veteran
Inspector12's Avatar
I haven't heard of anyone making more than 20# boost with one and really don't want to be the first to try at $800 for the kit.
On my Black car I made 23# with the 408 and so far that is about all I have made on the 347 because of a fuel issue, but should be @25-27 at 6500 on the little motor. Very nice numbers you have with your set up.
Old 09-01-2009, 10:44 PM
  #71
Hey Inspector, I was referring to people making over 20# using the Cartek Flip Drive. What pulley system are you using? Nice builds by the way.
Old 09-01-2009, 10:48 PM
  #72
TT-TECH Veteran
You are making 23# with the flip drive? I thought it was a Corvette specific part.
No. Just normal stuff for an F-body. You said you didn't know of anyone making more than 20lbs etc... Its an 8 rib setup no cog. Although I wish I could have a cog.
Old 09-01-2009, 11:03 PM
  #73
Gotcha - another guy recommended the Cartek Flip Drive to eliminate the slip problems I was having and I had responded that I was not aware of anyone using them over 20# boost. Vettes do not have a lot of room and you have to spin the blower, alternatore and power steering pump off the crank. Belt wrap / traction is a problem, so Cartek created a "Flip Drive? that allows you to spin the PS pump and alternator off the inner part of the damper that also spins the AC pump. This allows the outer section of the damper to spin the blower by itself, which takes a lot of strain off the components, allows you to use shorter belts and get better wrap to reduce slipping the blower. I did not want to be the first one to try one of these systems at $1,000 each after I just spent $1,000 on a 10-rib, which was an upgrade to my $900 8-rib. However, they may let me do some testing to see if they work because of the visibility my car has in the Corvette community. We will see - I would like to get something worked out.
Old 09-01-2009, 11:11 PM
  #74
T-Bones Goat's Avatar
Awesome build!!!! I can't wait to see what it does in the mile. When is that?
Old 09-02-2009, 03:58 AM
  #75
TT-TECH Veteran
I see what you were saying. Yeah I looked at the flip drive when they had just released it and well as you know is directed for the vette owners although I had not ruled out modification to use on an F-body etc... I haven't had a ton of belt issues although if I don't have everything just right it will slip. I have to make sure I clean the pulleys if it has slipped to clean off the residue of the slipping belt, then reinstall belt and make sure the tensioner has the correct tension before beating on it etc... I am sure you will find some good help from the flip kit. GL!
Old 09-02-2009, 11:16 AM
  #76
wforty94's Avatar
hey Inspector12, are you using the F1A, F1C, or F1R blower? and also, are you using the ATI 8 rib or SDCE 8 rib tensioning system?
Old 09-02-2009, 12:33 PM
  #77
It is in October. It is a really fun event. We usually camp out at the track and have a party throughout the night.
http://www.texasmile.net/
Old 09-02-2009, 12:57 PM
  #78
TT-TECH Veteran
Yeah its an F1R with a ATI 8 rib it started out as and SDCE lol!
Old 09-02-2009, 08:26 PM
  #79
Damn, those pictures are what it's all about!! Of course we all want that 200mph jacket but the BS is what makes it great! Do you have any idea what power to weight ratio it takes to hit 200 considering the car is set up correctly aero wise?
Old 09-02-2009, 09:26 PM
  #80
Mr.Big's Avatar
with the right wind conditions it's been done with 850rw at 3300lbs... usually around 900hp for 3800lbs... weight is not quite as big a deal as 1/4 mile...
Quick Reply: F1R 427 C6...numbers
