Turbo kits that keep A/C???
Old Jun 8, 2009 | 08:05 PM
Reject's Avatar
Originally Posted by CamaroCoby
Details please reject??
basically it's a stock short block with arp head studs on 317 heads with patriot gold springs topping the top side. when i first boosted it it had 86k miles on the engine it now has 90k i run at 16 pounds with the tc76f1 turbo. the manifolds are facing normal as they would on a stock ls1 with the driver side going under the tranny/engine mating surfaces into a 3 inch merge on the passenger side. from there it goes under the compressor but above the bmr turbo kmember to the front of the engine where it meets up with the turbo.
it's a fun little setup, keeps the AC and everything in the stock location.
hope that helps, if you have any more questions hit me up. i'm currently selling it to a friend becuase i'm going with a bigger setup now and turning the car into a track car. it's been a fun project. i have more fun building it than racing it lol
Old Jun 8, 2009 | 08:18 PM
CamaroCoby's Avatar
Cool! Thanks for the info. I want to do a turbo setup bad, I wanted to do a rear-mount but I think I've changed my mind. I'm looking at front-mount setups but I'm on a budget.
Old Jun 8, 2009 | 08:51 PM
elias_799's Avatar
^^^ be very careful turbo builds can get very unexpectedly expensive. trust me i know.
i like how the aps kit was designed. one day i might upgrade to it. but from what i hear is that their turbos are garbage for the f body's
Old Jun 8, 2009 | 09:01 PM
xXxSilveradoxXx's Avatar
Originally Posted by elias_799
I like how the aps kit was designed. one day i might upgrade to it. but from what i hear is that their turbos are garbage for the f body's
Their turbos are crap from what I understand. If I do buy a new APS kit I'll sell the turbos right off the bat. I'm sure there is no shortage of APS guys needing new turbos. Then, I'll have to call Turbonetics for some bigger, ball-bearing turbos.
Old Jun 8, 2009 | 09:39 PM
F-BodyGuy98's Avatar
i have had an STS kit on the car now for 2 and a half years, and i only wish i had dug deeper to realize how many front mount kits there are out there before i bought what i did, dont get me wrong the STS set up is a good quick, cheap and easy way into F.I. but i would love to upgrade. any one have any sugestions as to how much i could possibly sell my kit for? it still works good as new.
Old Jun 8, 2009 | 10:03 PM
Reject's Avatar
why sell it, just move everything up front, you have everythying you need, just need to stuff it under the hood now
Old Jun 8, 2009 | 10:10 PM
how much fab work would there be to do a conversion like that?
Old Jun 8, 2009 | 11:24 PM
CamaroCoby's Avatar
I would keep the turbo,bov,and wastegate,sell the other parts and with that money buy the hot piping and down pipe from josh @ kytp. I think its like a grand for it. Correct me if I'm wrong people. Then you would just need odd and end litttle stuff.
Old Jun 8, 2009 | 11:29 PM
i know this answer is prolly out there some were but how much power can a stock crank hold? ive heard only 500...but i read in onther post that the stock crank would be good for 6-700rwhp? im trying to narrow my possabilities..i have about a thousand ideas running through my head and i think im getting close..i can get my hands on a complete 6.0 truck motor for $400, wiring harness and all...what would be a good set of heads to run? ive read that the stock 346-370 c.i. is good for a steet/strip set up which is what im going for, im just wanting to get somethin going...
Old Jun 8, 2009 | 11:35 PM
LS1Silverado05's Avatar
Its going to be the rods and pistons that you need to concentrate on. Stock cranks can hold lots of power... are you on stock internals now?...
Old Jun 8, 2009 | 11:39 PM
right on, umm, being that i recently ran a fastest of a 12.41@112.7 with a bone stock LS1 that has roughly 97k on it, i know a rear is in order, but were could i possibly see myself running if i add an LS6 intake, TB, FMIC, 76mm Turbo, and stiffer valve springs and stronger pushrods, and upping the boost?
Old Jun 8, 2009 | 11:44 PM
  #32
tripblackls1's Avatar
so your car came stock with that turbo hanging off its *** lol
Old Jun 8, 2009 | 11:47 PM
  #33
shut up jerry....lol
Old Jun 8, 2009 | 11:54 PM
  #34
Too broad for me to try and answer... but Im sure that in short the answer is... alot faster LOL...
What was your combo when you ran the 12.4?... The 450hp in your sig will take you a hell of alot faster than 12.4s...so I guess it was before that?...
Old Jun 9, 2009 | 12:01 AM
  #35
the 12.4 was with the 450rwhp...it was only like 3 or 4 weekends ago
Old Jun 9, 2009 | 12:02 AM
  #36
CamaroCoby's Avatar
The question is how much boost is you stock internal 346 gonna hold when you do all that. I would guess 12.00
Old Jun 9, 2009 | 12:08 AM
  #37
im just wanting to see a pass that puts me deep into the 11's. the 6.0 truck motor is going to be the serious build, but im just wanting to push the stocker to its limits...i know they say that 98 has the weakest rod bolts out of any LS1 and that they can barley manage 500 hp. well im already making 517 at the motor...so im gonna keep going till she blows...would an LS6 intake work for the build or should i go with the edlebrock?
Old Jun 9, 2009 | 07:14 AM
  #38
Originally Posted by f-bodyguy98
would an ls6 intake work for the build or should i go with the edlebrock?
f.a.s.t.
Old Jun 9, 2009 | 07:32 PM
  #39
Originally Posted by xXxSilveradoxXx
f.a.s.t.
im on a slight budget...f.a.s.t. is a bit pricey, but ive considered them
Old Jun 9, 2009 | 07:54 PM
  #40
Reject's Avatar
i would spend that near 1000 bucks on something else.... an increase in boost would make up for that 1000 bucks spent on that intake
