Where to buy an STS kit?
#2 I don't have much faith in the average turbo setup. It does take twice as much hp to go the same speeds in the 1/4 or whatever.
#3 I called sts and asked about a twin setup for fbodies and they said nobody was working on one, but I see one where the owner built one for his ta in gmhightechperformance. The company doesn't know about itself.
#4 Sir with your one post in this forum we can tell you registered on ls1tech after swinging off of sts's ***** just to insult us and mention things you don't know about. We, for the most part about (95%) do not weld mufflers on our cars
We bolt them up.#5 The best bang for the buck is nitrous, followed by heads/cam, followed by mixing the two and the price still has potential to be cheaper than one of your sts turbo kits that will push maybe 405rwhp and still run only marginally better than my bolt-on car.
You and I both know 450rwhp out of an all motor car is faster than 450rwhp in a turbo car all else being equal.
I called sts not long ago and talked to a vince or lance and asked him about the TT system on the ta in the gmhightechperformance magazine I get and he said it didn't exist. I was like what?
Also, the sts kit might be nice to you, but it is not to me for the money. I'd rather spend $1600 and have a decked out N20 kit(still get my 30.1mpg) and spank a stock engined sts car all day long(all else equal)
Oh and yea refilling n20. It wouldn't be as expensive as you think. I wouldn't be wasting it on sts cars lol I'd be saving it for bikes and exotics, unless I got whooped by a sts car with quite a bit more done, then I'd ask for a rematch with my bottle on. lol
and I apologize for my previous post when I insulted you.
Oh and yea refilling n20. It wouldn't be as expensive as you think. I wouldn't be wasting it on sts cars lol I'd be saving i for bikes and exotics, unless I got whooped by a sts car with quite a bit more done, then I'd ask for a rematch with my bottle on. lol
If you both had the same rwhp n20 vs turbo, I'd probably pick the spray still but I'd only be 50% confident about it because that turbo could already be spooled up and ready.
If both can keep traction(and believe it or not it is possible because it happens) the n20 car can put all 450rwhp down in each gear including 1st. Now tell me, can your turbo car put down the full hp of, what 4th gear, in 1st? I think not. About every turbo setup I've seen takes off ok in 1st maybe the same for 2nd maybe not and about 4th gear its doing 300mph.
Now a n20 car would be most likely putting down its full rwhp in 1st 2nd 3rd...etc and end up winning the race due to more power being put down at all times for the same given max rwhp level.
If I had two cars both 450rwhp one turbo and one n20 I'd pick n20.
Yes a properly set up turbo car can make full power in 1st gear and carry it all the way thru every gear. My GN made almost 600 ftlbs of at 3500 rpms and was over 500 ftlbs at every RPM on a pull and there was nothing exotic about it. It had stock cast crank, stock cast rods, stock heads with mild port work, stock exhasut manifolds, and a bone stock intake, throttle body and mass air. My GN ran 10.70's at 3700 pounds with only 540 rwhp so your theory of taking twice as much HP on a turbo car doesn't hold water. My GN was traction limited or it could have gone faster. Our local track does not allow slicks and the combination of poor track prep, DR's and totally stock susp did not work too well, but it mph'ed over 130 a few times so it had plenty left. Best 60' was a spinning 1.69
I've never seen an out of the box turbo kit for a ls1 put it into the 10s
So my theory does hold water. your car is like the moisture that evaporates so slowly that no one knows about it.
...boost gage, no need for pulles or No2 injectors in the end to each is his own.... no need to fight on which is better or worse. personally i think the sts is more driver friendly not race car stats although a few have broken in to the 10's and below...https://ls1tech.com/forums/forced-in...lmr-build.html
http://www.gmhightechperformance.com...nce/index.html
That would be my dream kit!... there I said it!
How much does that kit cost and is that a daily driver? The carb style intake... is it literally carbed now? I will stay fuel injected. I don't want to give up the new stb I bought yesterday either. I'm sure it'd fit an ls6 manifold though, right?
from my understanding stock ls1 rings are only good to 500rwhp and the rod bolts to 6800rpms or something...
