help me pick pistions
8.5:1 is very low compression and is more for a high boost pump gas motor
you can also lower your compression with the cylinder heads. 317 will take the stock ls1 to about 9:5.1 depending on the head gasket.
I was not reccomending a stock piston just saying that they will hold fine at 8 psi.
EDIT: Just to clarify I mean dished Mahle's, I haven't heard any problems with the flat tops, but I'd assume they are the same alloy so ehh..
