Rule 3700 IC pump flow test.
Old Jun 15, 2009 | 10:19 PM
qqwqeqwrqwqtq's Avatar
Originally Posted by onfire
Good point. I'm using twin 1000hp Garrett cores....we'll see.
In a single unit or 2 separate units?
Old Jun 15, 2009 | 11:45 PM
onfire's Avatar
Coal Mining Director
Played with it both ways and was easier to package the unit in the nose as one piece. Basically, kept the single 3.50 outlet and the twin 2.50 inlet. Tank's in the hatch under the flip cover, pump's in the tank, hose's under the car.
Old Jun 16, 2009 | 06:56 AM
veee8's Avatar
Almost same setup as mine, IC is V-banded right to the compressor housing in the nose. Seems to work pretty good.
Old Feb 21, 2010 | 07:09 PM
ninetres's Avatar
Back from the dead. JESUS Phil that viedo is nuts. What a difference.
Do you, and any other big HP A2W guys, think the rule 2000 will suffice for my 2000hp intercooler? Mounted in-tank, 12 volts, 1" lines? Or should I run the 3700?
I estimate 1400whp tops this season. Twin.......60s
Also, what is the common way to plumb these inside the tank? Kinda lame how the fitting on the pump is 1-1/8". Can a 1-1/8" hose be clamped onto a 1" barb fitting inside the tank Just trying to visualize how this thing hooks up to a 1" line that feeds the IC.
Old Feb 21, 2010 | 07:56 PM
onfire's Avatar
I'm running the 3700 and think that it is marginal at best for my 1000rwhp ( and I know many are running the smaller pumps with success). I had to argue with Robert to get the 3700....some thinks it's overkill...I think it's not much pump with any head against it. I would not thnink about a smaller Rule...they're cheap $.
Old Feb 21, 2010 | 08:11 PM
ninetres's Avatar
I read your previous posts. So interesting IMO as it seems so many people run them. Are there any other options that aren't $300+????
What type of hose/fittings do you run from the 3700---> the edge of the tank? And what size lines do you run to your IC?
Old Feb 21, 2010 | 10:32 PM
onfire's Avatar
1.25 flexhose in the tank. -16 from the tank to the IC and back to the tank.
Old Feb 22, 2010 | 12:00 AM
ninetres's Avatar
Hmmm. You must run a 1.5"--1.25" reducer fitting off the pump then eh? what do you attach the flex hose to inside the tank? do you just weld a round metal tube on the wall to clamp the hose on to? Pics? SOrry, just trying to visualize it.
Old Feb 22, 2010 | 09:59 AM
Phil99vette's Avatar
7 Second Club
I can tell you, I run the 3700, added a 2nd pump and made very little difference in IATs....
Old Feb 22, 2010 | 10:27 AM
onfire's Avatar
Pump - hose- 1.25 aluminum tube - ANbung.
Old Feb 22, 2010 | 10:29 AM
onfire's Avatar
Over sized IC cores will have less effect from increased flow.
Old Feb 22, 2010 | 11:52 PM
  #32
ninetres's Avatar
Onfire, I am stil trying to figure this out.......what type of adapter did you use on the pump to run a 1.25" flex line? I am reading everywhere that the 3700 has a 1.5" discharge? I have been looking for adapter fittings for them and can't find them anywhere. Where did you get yours?
I'm going to go with the 3700 gold series cause I found it for only $14X.00 on some website.
Old Feb 23, 2010 | 10:19 AM
  #33
onfire's Avatar
http://www.chiseledperformance.net/watertanks.htm
He built mine....some pictures there to look at.
Old Feb 23, 2010 | 10:26 AM
  #34
Fireball's Avatar
I ran a rule 2000 in my 5gal tank and a 1500hp I/C (Reichard Racing minicube). Ran -12 from the tank to I/C and -12 return. IATs never eclipsed 90F at 1600 fwhp.
Old Mar 12, 2010 | 09:09 PM
  #35
ninetres's Avatar
So I got my 3700 today, and some 1.25" bilge flexhose I ordered with it. Here is a funny issue. The little "slip" sections on the hose every 12" is only big enough to slip INSIDE the outlet of the pump. I measured the hose and it is ~1.25". Do I need to order some 1.5" hose??? I could have swore all you guys said you were running 1.25" hose.
Old Mar 13, 2010 | 08:08 AM
  #36
7 Second Club
I went to home depot and got mine. I took a measuring tape, some measure outside, some inside.
Old Mar 13, 2010 | 09:30 AM
  #37
MIGHTYMOUSE's Avatar
scored a rule 2000 on ebay for $46 to replace my 1500. anybody that wants a 1500 lemme know it seem'd to work well.
