Rule 3700 IC pump flow test.
Old Jun 14, 2009 | 10:27 AM
onfire's Avatar
Coal Mining Director
Default Rule 3700 IC pump flow test.
Rule 3700 flow test. PSI kills the output of these pumps. Easy way to install an IC pump though.....
Old Jun 14, 2009 | 01:48 PM
kp's Avatar
kp
What do you expect for what they cost
Seen some pretty damn fast cars with those in the tank so they work I guess, how much flow you actually need would be the question..
Old Jun 14, 2009 | 03:20 PM
onfire's Avatar
A L O T of folks use them. The 2000 is very common and is much smaller.
Proof for me will be if it can keep the IC cool enough to start a run around 45F and end around 75-80F.
"IF" I can get all this junk hidden in the car.....
Old Jun 14, 2009 | 04:32 PM
slow67's Avatar
Gingervitis Addict
Go to the intank pump (with the built in sump). Phil (I think it was anyway) did a test and it flowed WAY more than the same rated GPH pump that had an inlet fitting.
Old Jun 14, 2009 | 05:58 PM
Phil99vette's Avatar
7 Second Club
Was that pump mounted inline or intank? If inline, move it intank and test and get back to me. You'll be very surprised. That pump will not work inline. Mine will shoot a 1.5" Jet blast of water 7'. It will drain a 30 gallon chest of water in 30 seconds mounted in the tank while outside takes considerably longer.
Old Jun 14, 2009 | 05:59 PM
7 Second Club
http://www.youtube.com/watch?v=MwlF2SnO-KY
1.5" feed 1st test
intank 2nd test
16 volts
1.25" ID hoses
3000hp intercooler
dual Y inlets
Old Jun 14, 2009 | 07:12 PM
onfire's Avatar
It's mounted at the bottom of a 6 gallon tank. It's the "bilge" model 3700 with the bottom basket inlet. It will also shoot a 1.5 inch stream 7-8ft out of the tank without a hose connected to it. I was going to measure open flow...but it's just too much flow to measure it accuately with what I'm using. When you add hose, IC core, etc....it still does a good job....but it flows what it flows...I did each test 5 times for accuracy.
Old Jun 14, 2009 | 07:38 PM
usd2sing's Avatar
what kind of pressure are you seeing in the lines/ic etc with that pump?
Edit: nevermind..the pic states it..
Old Jun 15, 2009 | 11:49 AM
7 Second Club
I tested mine through the intercooler core, Did the pump have a hose feeding it or was it mounted intank?
Old Jun 15, 2009 | 12:41 PM
onfire's Avatar
Mounted in the bottom of a 6 gallon tank with 5 gallons of H20 in it.
Keep in mind...big difference between 13v and 16v. These pumps are very voltage and psi sensitive.
Old Jun 15, 2009 | 03:56 PM
7 Second Club
It would be interesting to see how meziere pump did in the same test.
Old Jun 15, 2009 | 04:08 PM
veee8's Avatar
I could send my pump for testing if interested, I still have a little down time right now. Meziere WP 136S. It has worked great for me so far, being mounted all the way in the hatch, and the IC is in the nose, and goes through a large heat exchanger too.
I would be curious to see the results of this little 136, I know the 336 would be better.
Old Jun 15, 2009 | 06:17 PM
onfire's Avatar
http://www.stewartcomponents.net/Mer...Code=ElectPump
This is supposed to be the gold standard.
Old Jun 15, 2009 | 06:21 PM
onfire's Avatar
Meziere WP 136S
Standard motor provides 20 gallons per minute free flow rating
6-7 amps
Rule 3700 pulls 20amps at 13.6v for comparison.
Old Jun 15, 2009 | 06:57 PM
MIGHTYMOUSE's Avatar
i got the baby 1500 but seems to work for me
http://videos.streetfire.net/video/i...ank_186951.htm
Old Jun 15, 2009 | 08:09 PM
bumpin_records's Avatar
my question is you guys who are submerging the pumps in the water tanks. how do you have the outlet routed to the inside of the tank? I have a aluminum 5 gallon tank with outlets welded on at the bottom.
Old Jun 15, 2009 | 09:02 PM
kp's Avatar
kp
Just dont overbuild based on that pump's high pressure flow, it doesnt need to move a lot of ice water to keep the temp down if its a good cooler.
Old Jun 15, 2009 | 09:18 PM
onfire's Avatar
Good point. I'm using twin 1000hp Garrett cores....we'll see.
Old Jun 15, 2009 | 09:21 PM
onfire's Avatar
Look a few pictures down on this link.
http://www.chiseledperformance.net/watertanks.htm
Old Jun 15, 2009 | 09:24 PM
onfire's Avatar
Do you have any AIT data without meth? The 3700 water return in the tank "looks" very similar to the vid link Phil posted...his pump is similar to the 3700, but will flow more at 16v.
