How much does temperature change HP on FI with meth?
Old Jun 14, 2009 | 01:56 PM
'Trust''s Avatar
Default How much does temperature change HP on FI with meth?
I'm just wondering everyones thoughts on this? How much does outside temperature affect HP on a FI car with meth? On all my dyno runs, even after 12, my IAT's don't go over 105, and are usually about 80* on an 75-80* day. I'm assuming even when its 95* that they will be similar but I know air density changes. So say I'm making 770RWHP on an 80* day, how much would it be down on a 90-100* day if IAT's remained constant but ambient temps were closer to that 90-100*?
I know on a car without meth it is affected quite a bit but I don't know if that is mainly because of IAT's or air density?
Old Jun 14, 2009 | 09:14 PM
OUTLAWZ RACING's Avatar
I have no dyno numbers to back it up but I guess 5-10 hp because of the air. Meth may cool the charge but it may not as be as low on a hotter day. Plus on hotter humid days boosted cars tend to be a little fat on the afr add that in with the meth and it may not feel as fast as it should. A good way to tell is to see if its pulling timing due to heat. I did some testing today it was 97-100 degrees today and crusing I was seeing 90 degree intake temps and on the meth it was around 79-87 through the run. My car was tuned in 80+ degree weather so the only time i feel a differance in the the way it pulls if the temp was 75- degree or lower hope this provide some insight.
Old Jun 14, 2009 | 09:35 PM
SilverSS's Avatar
I don't know how much hp exactly but it my car feels like +75 to 100rwhp in 30 degree weather than when it's hot out. Maybe not but it sure feels a lot faster.
Old Jun 14, 2009 | 10:24 PM
'Trust''s Avatar
Well in temps below 75* I'm sure it will pick up quite a bit, it was tuned when it was 80*. I'm just wondering how much it will lose getting hotter. I was thinking like 50RWHP, which is fine, but if its anything like 100 I'll probably stay off beating on it. I bet in cool weather I'll pick up 50, maybe.
If its only 5-10 I'm not even sweating that. Anybody else have any input?
Old Jun 15, 2009 | 06:24 AM
engineermike's Avatar
Methanol does not increase the Oxygen density of the charge. This should answer your question.
Old Jun 15, 2009 | 07:39 AM
AFASTYZFR1's Avatar
I have a FMIC and alkycontrol kit that is maxed out and I feel a big difference when its warm out......guessing at least 30 hp
Old Jun 15, 2009 | 08:01 AM
moehorsepower's Avatar
I can tell you on mine without meth I was loosing 100+ hp on a hot day. This was verified on the Dyno!!
Old Jun 15, 2009 | 08:11 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
I think you will lose HP, but not due to the IATs alone, its probably more likely going to lose power because of the lower boost number you will experience on a hot day with less dense air. You know by now what a few psi can do to HP after removing the hat and filter on your last dyno session
Old Jun 15, 2009 | 09:52 AM
'Trust''s Avatar
Thats true, I just wonder how much PSI it will be down in 15* difference.
I know that, thats the whole reasoning for my question, and it doesn't.
Old Jun 15, 2009 | 01:25 PM
Louis's Avatar
70-80* ambient I see 45-60* IATs after a long pull with meth, with out it, I see 30-50 above ambient after a pull.
Old Jun 15, 2009 | 02:18 PM
'Trust''s Avatar
^ Any compared dynos?
