oil in cold side tubing
i have a 6.0l with a rear mount tc76 return oil pump is a weldon 9200a a -3feed with a restrictor and a -10 return with a 45deg fitting off the turbo and about 1 ft of line between the turbo and return pump and 90deg fittings on the pump and oil pan and like 8 feet from the pump to the oil pan
pcv system is the ls6 valley cover and everything else capped and a breather on the pass valve cover
any help as to why im getting so much oil would be appreciated
thanks, Gary
I thought an oil leak in any part of the turbo was bad?
Can anyone chime in on this?
