Budget Minded 500whp (LT1)
Old Jun 19, 2009 | 09:51 AM
TAEnvy's Avatar
Default Budget Minded 500whp (LT1)
Hey Guys.
How would YOU build a 500whp (through an M6) boost car, with a budget mindset.
I know boost isnt exaclty budget friendly but, I mean build it right but not overkill for the power level. For example I doubt an F1 is needed for 500whp.
Forget "room to grow" just think about 500whp, and something relatively reliable.
How would you do it? S/C or T/C? Enigne Size? Parts? Tuning?
Once I finish up what Im working on now, I want to do a motor and was thinking spray, but I want to price out boost to and see if its worth the additional investment.
What do you think it would cost to get it done?
Old Jun 19, 2009 | 10:20 AM
My2kz28's Avatar
You will need to al least upgrade the pistons to make 500 rwhp reliably. You can make 500 whp with a 383 and a 100 shot, or you can uprade the rods and pistons, put arp main bolts in, and get a d1sc tuner kit. I made 450 rwhp on my stock lt1 with the twin highflow d1sc 8 psi kit, and ended up having to rebuild due to blow by. The rings couldnt seal the cylinders. Im sure anyone on here is going to recommend you to get at least a new set of forged slugs and rods, but while youre at you might as well splay the block and run a forged crank. IMO there is not a budget build for 500 whp with an lt1. Ls1 is a different story.
Old Jun 19, 2009 | 10:24 AM
TAEnvy's Avatar
Not neccesarily a budget build, but I dont want to be spending money where its not neccesary.
I was hoping stock crank, some good I beams (and rod bolts) and some good forged pistons, and possibly studded mains (2 bolt) would be enough, bottom end wise.
TAEnvy's Avatar
Remeber Im not looking for room to grow just 500whp
Old Jun 19, 2009 | 10:31 AM
My2kz28's Avatar
im making 650 whp with 2 bolt studded mains with arp bolts, stock crank, and eagle forged h beams and srp forged dished slugs ~9.0:1 compression. But ive aslo got ported heads and a 224 236 cam. Who knows how long it will last for, but id say if you ran a similar short block, got a d1sc head unit and fabbed up a ebay fmic youd make 500 pretty reliably.
Old Jun 19, 2009 | 10:49 AM
TAEnvy's Avatar
Thank you. Very Helpful.
What do you use for tuning?
Anyone else?
Old Jun 19, 2009 | 12:25 PM
My2kz28's Avatar
Anyone else?
LT1 EDIT
you will likely only need a 255 inline pump and 42 lb injectors with a solid tune, but get some more opinions on that since fueling/tuning is so important.
Old Jun 19, 2009 | 12:32 PM
TAEnvy's Avatar
Whats the going price on LT1 edit nowadays.
Would it be better to switch to OBDI adn try tunercats?
Old Jun 19, 2009 | 01:32 PM
DopdBrd's Avatar
I've seen LOTS of people run the stock crank and rods at that power level. Turn the stock crank, ARP bolts in the stock rods and then get a good forged Blower piston and you should be fine on the bottom end. Most of the reliability is going to come in the form of your tune. Don't get too greedy and be relatively conservative on the tune.
You should be able to make 500HP and drive it with no problems.
Old Jun 20, 2009 | 12:59 PM
boosted4life's Avatar
I make over 500 but idk if you would call it budget minded, haha. I have a forged 355 with a 76mm turbo.
Old Jun 20, 2009 | 01:13 PM
Blk99ek's Avatar
I made 500 hp with stock crank stock heads cheap forged pistons 230 236 cam and stock Throttle body with long tubes on a 200 shot and I spray my car everytime I drive it LOL very reliable I sprayed 125 dry shot withstock everything for over a year just deceided to rebuild it for the hell of it and everything looked awesome in the motor for being stock with a cam and nitrious
Old Jun 20, 2009 | 01:19 PM
Gordon0652's Avatar
you WILL regret that...
butttt
Just do an STS kit with a new rear end. The stock engine will hold!
Old Jun 21, 2009 | 03:03 PM
TAEnvy's Avatar
butttt
Not really. There is ALWAYS room to grow on engines, wether you purposely build it in or not.
For example, I want to go relatively stock bottom end, so I could easily change the top end to gain some power, and then if the rotating assembly becomes the weak point, then my room to grow lies in a new motor.
But really I should be happy with 500whp.
Ive driven 600-700whp cars on the street and although they are fun, they are pretty much fun when you have someone to race, or play with, I think I would have much more fun in a STREET car with 500-600whp.
I dont think I would want more than 600whp for a street car, and anyways I dont have the money right now for it anyways.
Oh and I prefer to not go with a rear mount, although I will consider it, im really just not a fan of rear mounts, although Id rathrer not turn this into a rear vs conventional mount arguement.
anyone else have any comments?
Also what turbo would you use, Im worried that the common T76 may be too big for the powerlevel and have nothing down low.
Id prefer myt powerband to be similar to a cammed car, smooth power delivery that just keeps coming and coming, with lots of midrange and top end.
I would prefer it not just HIT right in the midrange.
Old Jun 21, 2009 | 05:26 PM
subarubill96's Avatar
id look up a board member by the name of Realquick on here. he pretty much is the turbo LT1 guy.
if it was me, id go with a budget built 383, stock ported heads and a tc-76 with one of jons log manifold kits through if i remember right "skinnies" was running high 10's with a 76 and a 355 with a stock crank.
MaxxMitchell's Avatar
Well, I helped a friend do a simple T76 set up 2 years back. LT1 with forged rods/pistons, comp pro mag rockers, guide plates, push rods, EWP, and only a ALT and that was it, no heads, no cam, no intake work. Log manifold turbo kit with a 3" DP, stock TH400 with a nitrous 4000 stall, on 11lbs for most of the pass it went 10.80s at about 127.
Old Jun 21, 2009 | 05:27 PM
lol yep skinnies is the guy
Old Jun 21, 2009 | 05:30 PM
lol i totally forgot about the stock heads too! that car was my inspiration to do up my old 95 Z28 but that damn ls1 bird came along and i fell in love. so funny we posted at the same time
Old Jun 22, 2009 | 04:41 PM
TAEnvy's Avatar
Could someone like ed wright tune a build like this or am I more limited to sell tuning stuff.
Im not really sure Im comfortable enough to tune this. I may have him do it and slightly tweak it later down the road to accomodate weather or other things.
Old Jun 22, 2009 | 06:02 PM
id say that depends on how much boost your running, MAF or Speed Density, how much you want/ need to play around, methanol injections, etc. id say for sure that you'll be able to handle at least 7-8 psi safely on a mail order with 60# injectors from my personal experience which may or may not put you were you want to be...for alittle while before the boost bug bites again
Old Jun 25, 2009 | 11:18 AM
baylove's Avatar
like stated above once you get to 500hp your gonna want 600hp and keep going on from there thats why i went and purchased a street bike now i want to put nitrous on the bike my goal is 500 rwhp with my procharged lt1 im going to stop there for now and save up for a forged bottom end and some other goodies let us know how it goes i will post my dyno results in a few weeks good luck
