If I hit the rev limiter under boost will it blow?
Old 06-23-2009, 10:34 PM
lbfd48's Avatar
Default If I hit the rev limiter under boost will it blow?
I just got my custom turbo truck tuned today. The tuner told me if I hit the revlimiter under boost, it will cut fuel and prob blow the motor, is this true? If so how do I prevent this from happen?
Old 06-23-2009, 10:45 PM
SilverSS's Avatar
I blew my motor hitting the rev limiter or at least that's the only reason I can think of that it blew. Boost was at 16psi with 100% meth still spraying when the fuel cut-off kicked in @7K due breaking traction. Cracked a cylinder. Don't know if hitting the rev limiter was the actual cause but im gonna raise the limiter past 7k in my new motor once it gets tuned.
Old 06-23-2009, 11:11 PM
lurker1978's Avatar
Complete fuel shut off will not blow the motor, but cut the fuel and still spray meth--yeah that will create a super lean condition and could melt a piston.
Old 06-24-2009, 12:13 AM
lbfd48's Avatar
This might help its a 99 ls1 317 heads 918 springs 10psi.
Old 06-24-2009, 06:37 AM
daniel6718's Avatar
it could cause some damage...to prevent it you need an ignition cut not a fuel cut...or put the limitor at like 7500 or so
Old 06-24-2009, 07:05 AM
smokinHawk's Avatar
i've hit the rev limiter many of time on hard boost, my engine didnt blow.
and it was set about 7200 and duty cycle on my injectors were %110
Old 06-24-2009, 07:57 AM
LS1Tech Sponsor
hellbents10's Avatar
Like stated above total fuel cut will not hurt it because the power will be gone instantly. If you are spraying a good amount of meth when it cuts the fuel then you will have troubles if it sprays enough to make hp still.
Old 06-24-2009, 09:08 AM
Dumb Ass Vette Moderator
ls1290's Avatar
I assume you bought a Lotto ticket right after that happened.
Old 06-24-2009, 09:12 AM
'Trust''s Avatar
That is interesting. How much is "enough to make hp"? Say a single nozzle Alky Control kit for example? 80/20 mix.
Old 06-24-2009, 09:26 AM
MY99TAWS6's Avatar
Factory turbo cars have rev limiters and they don't blow the motor when you hit them. I have never heard of this before.Fact using a two step is common with turbo cars and it don't hurt anything.
Old 06-24-2009, 10:16 AM
smokinHawk's Avatar
haha, should have, was running about 85psi of fuel pressure.
ran 135mph at about 3700-3800lbs raceweight. was trying to get to 130mph, over shot it by 5.
those were with some 42lb injectors, got 96's now.
Old 06-24-2009, 10:49 AM
moehorsepower's Avatar
Now using Nitrous and hitting the factory rev limiter, Thats a whole different story....Just say Ka-Boom!
Old 06-24-2009, 11:07 AM
MY99TAWS6's Avatar
Nitrous usually you run a window switch so it dont' come on too low and don't spray into the limiter.
Old 06-24-2009, 01:32 PM
Yup, tell those fools that say they don't need no window switch, believe me I have seen a few...
Old 06-24-2009, 02:41 PM
Drewstein's Avatar
Should have been running a window switch on the meth.
Another reason I don't run that crap.
Old 06-24-2009, 04:56 PM
7 Second Club
NicD's Avatar
As long as you are not using another fuel adder like a meth kit or anything else that is adding fuel like a wet nitrous kit than no you will not blow your motor by hitting the rev limiter. The factory computer cuts all fuel going in to each cylinder as necessary, not half or anything other amount so it will not run lean.
Old 06-24-2009, 05:02 PM
SilverSS's Avatar
Good for you! It's just more **** to go wrong. I'm leaving it out with my next build.
Old 06-24-2009, 05:34 PM
stevieturbo's Avatar
Or just dont hit the rev limiter ?
Old 06-24-2009, 06:55 PM
BigRich954RR's Avatar
ding ding
Old 06-24-2009, 07:05 PM
Sluggish's Avatar
2-steps pull the spark out not the fuel.
Quick Reply: If I hit the rev limiter under boost will it blow?
