TurboD Lt1
I hope you do not go with a sts kit. that is weak , a joke and not worth the time . Turbos go under your hood not your a**
here is a guy that builds nice turbo kits . www.lt1boost.net . nice guy . Great guy from
www.theturboforums.com
He has kits starting at $1500-$6000. 550-1000rwhp . also you can make nice power at 5700 rpm . shoud be at full bost by then.
I have a s480 DIY kit on my car.
as far as the bottom end you can get 450rwhp out a lt1. But i would say upgrade to stock crank ,ohio crank h-beam rods and speed-pro dish pistons pistons (summitracing). should be good for a safe 560rwhp short block
![Barf](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_barf.gif)
