sell fast intake or not?
I have posted tons of links to threads with people running to 20psi on the fast no problems at all and there are some pretty sure even higher boost levels.
Not sure what the heck happened to your intake but don't think its very common.
I am so far running to 8psi daily, zero problems,couple thousand miles already since put the turbos ,408 and fast on the car.I am a bit leary about the burst panels could maybe have left them out since don't think direct port can backfire like wet single nozzle kit.
I kept the fast for the direct port option. To be able to run low boost and small shot and get instant spool and great cooling effect. Also think the fast should still give better area under the curve on or off boost. I have seen some great dynos with them on boosted applications. There are several in the LS1 dyno book.
Two big thousand hp build ups with fast intakes on the afr website as well.
Aps ran fast on their test mule.
Tony Mamo who is well known on the board has said lots of people are running fast intakes on boosted builds no problem.
Sell it if you want it your choice but really I would try it first. Maybe you want to run a small shot of spray at some point in time too.
I made sure to use rtv where the gasket joins inside the shell and loctite on the shell joining hardware.I also drilled and tapped the map sensor and moved it off the fast intake. Just have vacuum port there now.
I have ran smoke machine test on the my car to make sure the fast is not leaking. It isn't. Will be trying some higher boost on it later this season and not too worried. Doubt will ever go past 15psi though. No real need to.
