cam question (Help please)
Old Nov 13, 2003 | 01:14 PM
sleepersilverado's Avatar
Default cam question (Help please)
well i know this has been asked time and time again. but i need to get something done in a hurry. the truck is deciding to chunk springs like once a week now.
I have a scsb truck with a compleetly built 5.3. 9.0:1 compression and stage two gtp heads. what cam recomendations would you have for probably 6300 rpms at the most. This is now going to be a turbo application.
Any help would be appreciated let me know if more info is needed.
Tia Ryan
Old Nov 13, 2003 | 03:21 PM
Ryan23silverado's Avatar
Hey Ryan check out the Lingenfelter GT-2 cam. It is a 207/220 .573/.580 117.5 lsa
My quick $.02
Old Nov 13, 2003 | 03:33 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
How many lbs of boost?
What fuel system?
Turbo setups seem to peak pretty low, so I'm thinking 218/224//114 for a smaller cam.
Old Nov 14, 2003 | 02:39 AM
it will see aprox 12 lbs. of boost but i will put it up to 20lbs when getting serious. as far as fuel. that is to be determined. only thing i have now is motor and it has been in the truck. but the cam has got to go. so i want to do it once like i planed to in the first place but that did not happen. also i recently decided on turbo over s/c due to speculation of some kits comming out in the near future.
Thanks i will prob try to order something tomorrow or mon at the latest.
this time instead of limping it home on the inner spring i had a toe bill of about 230$
thanks and let me here some more
Ryan
Old Nov 14, 2003 | 05:54 AM
smokinHawk's Avatar
since reving it only to 6300, id try a 226/222-116
if you want it more freindly id try a 222/218-116
reverse splits will work well with a turbo.
Old Nov 14, 2003 | 09:00 AM
SS00Blue's Avatar
I've gotten some second hand Dutweiller opinions that traditional splits with roughly 6 more degrees on the exhaust side work very well. Add to that the opinion that a lower LSA, around 112, allows fresh (read: cooler) charge air into the cylinder, while not making the turbo work too much harder.
I was interested in the cam PSJ quoted, but on a 112 LSA.
FWIW, the turbo king of this site has a traditional split, I'm fairly sure (Harlan). Good enough for me.
SC-
Old Nov 17, 2003 | 02:37 AM
ok how you think this one will work?
228/224-114 .577/.571 with two degrees ground in
