Spooling with NOS
Old Nov 13, 2003 | 05:23 PM
I8Your03Cobra's Avatar
Default Spooling with NOS
I was thinking of getting a 75 shoot to spool up and then a hop switch so when it hit's full boost the NOS shut off is this a good idea? Any experince? Thanks
Old Nov 14, 2003 | 06:01 AM
smokinHawk's Avatar
how big of turbo you going to use, these 5.7L pusha turbo pretty good.
i get full 10lbs of boost at 2700rpm with my T76.
the supra guys do it, but they got a punny 3.0L
Old Nov 14, 2003 | 09:44 PM
cdk4219's Avatar
What about hitting the exhaust side with compressed CO2 to spool up?
Old Nov 15, 2003 | 10:55 AM
y2khawk's Avatar
IMO, i wouldn't bother. I hit full boost by 3500, but then again i'm spooling a PAIR of T-66's
With properly sized turbine housing(s) and maybe a boost controller you won't need any help.
Old Nov 15, 2003 | 11:10 AM
smokinHawk's Avatar
i was going to ask you when you see full boost
heck thats only 800rpms after i see boost with my single t76
to think adding a turbo bout the same size only slows spool down that much
what size is your AR exhasut housings?
Old Nov 15, 2003 | 11:17 AM
y2khawk's Avatar
.69A/R P-trim, ball bearing helps though
Old Nov 15, 2003 | 11:58 AM
ChrisB's Avatar
Quite a few of the aftermarket efi kits support "anti-lag" features whereby an extra injector(s) is plumbed to provide fuel in the exhaust to spool up the turbo quicker - or you can even just run the main injectors extra rich. Burning fuel in the exhaust will spool up your turbo very quickly
Old Nov 15, 2003 | 01:43 PM
MIGHTYMOUSE's Avatar
i was thinking that chris.. anyone with a turbo 'sucessfully' sported an afterburner before?
I8yourcobra.. if you spray you are not going to want to turn it off at full boost. just let her eat... my opninon is if you are gonna spray like that, why bother with the turbo at all?
Old Nov 15, 2003 | 02:57 PM
i just found this if you have your heart set on it.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442377205
nice adjustable boost switch there.. hmm.
Old Nov 15, 2003 | 05:00 PM
DaveSchott's Avatar
Talking
Doesn't a two step do this automatically since it doesn't shut off injector pulses, just the spark? (i guess that's not a question it is a fact). Remember how a 2-step melted cats? believe it was blackhawk2000 who melted his? whatever happened to him?
Old Nov 15, 2003 | 06:28 PM
ChrisB's Avatar
Yep, that is why m6 turbo cars really *need* a two step (plus you have a bit more air flowing through which helps). But with the aftermarket anti-lag setups they can go between gear shifts, or even at low rpm's when you aren't in boost (depends on the setup how configurable it is).
Old Nov 16, 2003 | 02:19 PM
Well im getting the STS kit Rear mounted Turbo (Go ahead and hat it all you want its all i can afford)the
the 60-1 is at full boost at 3000rpms im getting aT-66 with my kit pobably a little more laggy thats why i am considering spaying with the hop switch. It will be nasty down low.
Old Nov 17, 2003 | 12:55 AM
roadrage's Avatar
AHAHAHA, it's also hazardous to any cars BEHIND the 2 step car.
Blackhawk dosent have the car anymore, he went into hiding, but i'm sure he's lurking here somewhere.
Speaking of where did someone go, did you always live in Ohio? I've been wondering where you went for a while
Old Nov 17, 2003 | 09:05 PM
DaveSchott's Avatar
Default how the hell did i end up in ohio?
RR, sending you a PM
