What's the realistic MAX for a MAF w. FI?
edit: Ok, if temp/etc aren't an issue, then what ~are~ the limitations of SD tuning? I'm in an emissions state, FWIW.
Your limit in the PCM is 512 g/sec, and 12k hz.
Larger maf housing= higher ceiling.
Take that info and use it to your advantage
So what you are saying is that MAFs are limited to certain VELOCITIES rather than VOLUME?
You can operate in maxed-MAF territory, but you will get WOT AFR swings that are dependent on the outside climate.
If your tuner uses HPTuner's, you CAN run totally SD WITHOUT FAILING THE MAF. Yep, not a single code. I would suggest you ask your tuner up front if he is SURE that he knows how to do this.
I swear this topic comes up as much as the "how much boost can a stock LS1 take"
