Safe Compression/boost on a stock LS1 bottom end?
e.g. if 8 psi is safe for 10.0:1, what amount of boost is safe for 10.5:1, 11.0:1, etc? Assumed Vortec S/C with intercooler, no meth or alky.
If you want to play it safe, get a set of 317 heads. They are cheap enough, a head swap is pretty straight forward, and a good tune will allow you to run 8 to 10 pounds of boost safely on a stock bottom motor.
