Dyno Runs on my twin 70mm Stock 6.0L.
ya I am sure once I turn the wick up it will make some good power,
Car went 9.5@143 on the limiter for the back half the track because the power is blowing through the converter HARD. Made a call to Lenny at ultimate and he is going to see what he can do with my converter so hopefully that will pick things up.
yes sir, .68 a/r hot sides. I am sure it can make a bunch more too but I wanna keep it alive for a while, I am gonna have lenny from ultimate fix me up with a converter.
hey, just for reference my buddies 97 twin turbo cobra runs 116mph 1/8 and 151mph 1/4 with an AOD that locks up in 3rd (no converter slip). To bad you couldn't get a lock up converter for the TH400.
good luck with the converter change, hope they get it right for you.
Ya I am thinking if the converter is right I should be around the 150 mark at the current power level. TCI May be able to get me set up now they are working thier magic to see what they can do.
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
