Dyno Runs on my twin 70mm Stock 6.0L.
Well I decided I might as well throw the car on the rollers and make sure the tune was half decent for some friday night action.
I was kindly rewarded when the first pull it broke up rich numerous times and still did 600 ish rwhp. 11 psi of boost/15 degrees of timing and breaking up in the 9's for AFR.
Second pull I got the tune a little closer it did 650ish still same boost/timing. Little cleaner AFR.
Third pull , still working on the tune..... 670rwhp/601 rwtq on 12psi/15-16 degrees of timing and a pretty rich afr of around 10.8 ish.
4th pull got the Afr cleaned up added 2 psi of boost and did 706 rwhp/625 rwtq on only 14 psi/15.5 degrees of timing and around 11.2-11.6 AFR.
I decided that was enough power to try out for the first time out. Overall I am up 130 rwhp and 103 rwtq on 2.5 psi less boost. This thing still has A LOT left in it but like I said I wanna see how it does on this for now.
I have also been driving the car a lot as well, to and from work Also made a 5.5 hour road trip for a bad *** local meet,street races etc and took down the following:
69 camaro, Full tub on 33x17 slicks, 502 on the bottle.
Hyabusa not sure on mods I think just a pipe
C6 Zo6 408,procharger -810 rwhp
I really did not think that this stock JUNK would make this much power especially on low boost. All numbers were made on GARBAGE 91 octane pump gas and meth. I will post the dyno chart as soon as I get a chance
Im hoping for 9.50@150 ish ... hard to say power wise it could still make a bunch more, this is all through a factory ls6 intake and ported tb as well as a th400 with a 3800 converter so I am sure the motor is making its fair share of power for what it is.
make sure you get some good vids! This is very similar to what Im putting together for my project... I might go a little smaller on the turbos to make sure it spools the way I want,
Very cool project!
Very cool project!
Nice kills, but it seems there is a mistake on the Vette. Either it must have been a C5 or the engine was a 427, because I can't figure out any reason someone would exchange a 408 for a LS7 427.
Sorry you are correct the car was not a Z rather just a base model C6, and the motor could be bigger but just heard through the grapevine its a 408. I did however see the dyno sheet for 810rwhp.
ya I am sure once I turn the wick up it will make some good power,
Car went 9.5@143 on the limiter for the back half the track because the power is blowing through the converter HARD. Made a call to Lenny at ultimate and he is going to see what he can do with my converter so hopefully that will pick things up.
