New best for Ninetres!!!! 18psi baby!!!!!
Old 07-21-2009, 10:19 PM
  #41
DanZ28's Avatar
Originally Posted by ninetres
8.50 is a tough number for a car like mine IMO. I have been chatting about turbo reducers with friends and it sounds like there is a point of diminishing returns with them. Its not like you can slap a 76mm reducers on a 106 and run killer times. I'm hearing it makes more sense to run a turbo closer in size to the maximum allowed limit. I'm just starting to make a list of changes for next year and I will talk to Jose for my turbo selection.
I heard Tim has several of there rules in place because he didn't want the turbo guys walking into this class and cleaning house.
You should talk to the turbo guys at the track as well I know of one in particular and the reducers are not much resriction at all the way it's made, at least his aren't. Your right, I was thinking more along the lines of an 88mm like the precision billet piece or even their non billet one, not a honking 106.
I'm sure Tim did have those reasons since it's the same problem other classes had and now their on a short track to make it more competitive. Look at the rule Tim did for the F1R in L10.5, your limited to certain cogs and pulley sizes and wont allow gear drives cause prochargers could do a sweep in that class as well.
I agree with FANTAZ28 about the twin 60's!
Anyway, I look forward to see what you come up with bro, i'm sure it'll be killer and should be alot of fun and glad more guys are coming out to support the WCHRA...
Old 07-21-2009, 11:05 PM
  #42
ninetres's Avatar
This is giving me new ideas! Expensive ideas
Old 07-22-2009, 02:24 AM
  #43
DanZ28's Avatar
So Addicting .
Old 07-22-2009, 01:49 PM
  #44
LS1TECH Sponsor
DrTurbo's Avatar
If its a 76mm inlet....lol, we can build factory cover thumpers with 76mm inlets...lol. 76/88
Old 07-22-2009, 04:46 PM
  #45
ninetres's Avatar
What about some sneaky twins? Like some 72mms with a 60mm inlet? What is my best option there? I need to trap in the 160+ range at 3300-3400lbs!
Old 07-22-2009, 04:47 PM
  #46
LS1TECH Sponsor
DrTurbo's Avatar
Yes we could do that as well. Single would be easier to plumb, but twins would rock the show!!
Old 07-22-2009, 05:29 PM
  #47
ninetres's Avatar
Soooooo twin 60mm inlets will allow for more power than a single 76 inlet? I know twins would be a bitch but I'd hate to spend all the money to upgrade my single, and enter all the races and still not be able to somewhat compete. They handicapped this class BIG TIME for the turbo cars. I'd like to shove it down their throat and wax the nitrous cars next year
Old 07-22-2009, 05:48 PM
  #48
lt1badbird's Avatar
what kind of power are you putting down
Old 07-22-2009, 05:50 PM
  #49
ninetres's Avatar
No clue. My car doesn't really ever see a dyno. Run 146mph (in 100+ degree heat!) and 3700lbs in a calculator and report back!
Old 07-22-2009, 07:20 PM
  #50
SPRAYED 01's Avatar
whats trans and rear gears are you running. Is this off a t-brake? Any dyno numbers.
Just trying to compare my car.
Alex
Old 07-22-2009, 07:37 PM
  #51
ninetres's Avatar
Alex
No dyno numbers (see my post above). TH400 trans, 3.25 gear, and 28x10.5s et drag. Yes, I leave on a trans brake. My 60' needs a lot of work. Should be in the 1.35 or better range.
Old 07-23-2009, 10:06 AM
  #52
allthrotle's Avatar
Well if you did that and started smoking the nitrous cars they'd probably put more restrictions on you and then you'd have to change your setup again.
Old 07-23-2009, 10:17 AM
  #53
ninetres's Avatar
I was being overly optimistic I also doubt they'd change the rules mid-season.
Old 07-23-2009, 10:27 AM
  #54
allthrotle's Avatar
haha you never know buddy, If you started wrecking shop on people they could be like you have to unhook all the spark plugs left side of your motor and add 1000lbs of weight.
Hey when do you think your car will be up and runnning again? I hella wanna see your car up closer. I only saw you go down the track a few times.
Old 07-23-2009, 10:37 AM
  #55
ninetres's Avatar
Its still running. I haven't tore it apart just yet! I might go out for one last night on Aug. 1st at Sac. Maybe grab a 9.20 if I can get it to leave and the air is nice!
Old 07-23-2009, 10:56 AM
  #56
allthrotle's Avatar
Well you should come up for Hot August Nights since its the first week in august, You definetly have places to stay if you wanna come up. I know you can stay at Picnic_George's house. Or you could stay at my place. We could get some good racing put together.
Old 07-23-2009, 11:40 AM
  #57
ninetres's Avatar
Work....and I'm out of vaction. I will be "sick" on the first I believe *cough cough* lol
Old 07-23-2009, 11:48 AM
  #58
allthrotle's Avatar
haha alright well Im gonna try and go on the 1st, let me know if you need a pit crew Im down to help.
Old 07-23-2009, 04:19 PM
  #59
LS1TECH Sponsor
DrTurbo's Avatar
I dare say its over 500rwhp??
Old 07-23-2009, 05:48 PM
  #60
ninetres's Avatar
Can you do me a favor and look into my best options for some twins with 60mm inlets. The class allows reducers so I can do some nasty 72s or something. Please let me know what brand and size twins will make the most power with a 60mm inlet. I only run 370 cubes and 9.1:1 compression.
Jose said the T6 GT88 would be the best single option with a 76mm inlet. I don't know much about that turbo but it didn't seem rated much higher than my ST80 with the race cover.
Quick Reply: New best for Ninetres!!!! 18psi baby!!!!!
