Boosted 5.3
Old Jul 22, 2009 | 04:41 PM
71ANTICARB's Avatar
Default Boosted 5.3
Hey Guys
Its been awhile since Ive been on. I have some questions hopefully ya'll can answer for me. Here is what i have, a 5.3 i purchased from the boneyard. I have completely disassembled it and its ready for the machine shop. I am going to be putting it in a 71 Chevelle. I am looking for a reliable 500rwhp. I am going be putting a turbo on it. I am also trying to do this on a budget. I would like some input on:
What cam (I was thinking LS6)
What heads (I was again thinking LS6)
What size turbo (I aint got no idea on this)
And what kind of boost I could run
Thanks any help would be greatly appreciated.
I will be keeping ya'll posted on the swap.
Old Jul 22, 2009 | 06:03 PM
pwrtrip75's Avatar
You dont need LS6 heads. maybe just LS1 heads, I have 6.0 heads it drops compression down to 8.6:1 but if your on a budget pass on the LS6 heads. You'll get beyond 500hp without them.
The Master Power T70 seems to be a good choice for the 5.3, people making over 600hp with them.
Mines a complete stock shortblock w/ 6.0l heads, Master power GT45 (kinda laggy) 15psi boost, 50 shot of spray, a cam i had laying around 224/224 112 and its been reliable for going on 3 years beating it pretty good. Makes about 640rwhp.
My friends BMW he put a 5.3 in it, budget build, 6.0 heads, MP T70, hasnt finished it yet though.
Old Jul 22, 2009 | 06:23 PM
blazin's Avatar
Im running a
G5x3 on 114 for a cam
T70 .96 car
Im gonna swap to ls1 heads but need to find out what headgasket to run.
No Idea on power yet.
Old Jul 22, 2009 | 06:30 PM
98Camarod's Avatar
I ordered 5.7l head gaskets and they sent me 6.0l. They said that is what they all use now. I'm guessing that's the same for the 5.3l
Old Jul 22, 2009 | 07:04 PM
deathbydisplacement's Avatar
im not sure on the head gaskets. But on the heads i would go with some ls1 mabey port and polish and go with a vic Jr intake with a intake elbow from intakeelbows.com
Old Jul 22, 2009 | 07:37 PM
pwrtrip75's Avatar
You use the gasket to match your head....5.7 head = 5.7 gasket, same with a 6.0= 6.0 gasket.
Old Jul 23, 2009 | 12:52 PM
spdrcr7882's Avatar
My setup is in my sig, makin 525 to the wheels, on 91 octane in the arizona heat, without any major issues.
Old Jul 24, 2009 | 02:35 PM
71ANTICARB's Avatar
Thanks for all the info. You guys are awsome but i thought that the 6.0L head had to big of valves to clear the stock 5.3L bore
Old Jul 26, 2009 | 11:08 AM
chevellepowered's Avatar
budget budget,,, stock 5.3 with stock heads,,, ls6 springs and cam, stock intake depends on ur car,, truck 42lbs injectors. single walbro 255 pump. mp t-70 turbo.. mastor power turbo,,, 600 bucks shipped taxed everthing, wastegate of ur choice, dont go cheap there, ..i got one used $175.. and a cheap intercooler ebay.. thatats 600hp at crank probly at 12psi,, 16 psi would be 700 hp at crank.. look up "turbo fairmount" he has dyno results.. running 9's
Old Jul 26, 2009 | 04:20 PM
MUSTANGBRKR02's Avatar
Which trucks came with 42lb injectors chevellepowered?
Old Jul 26, 2009 | 04:46 PM
the 8.1 liters, think thats equals 496 ci
Old Jul 26, 2009 | 04:49 PM
the marine injectors or gas? Are they EV1 connectors?
Old Jul 26, 2009 | 07:51 PM
the marine injectors.. i dont kno ev1,, they plugged write into my stock truck harrness.. gas.. im using them on my t70 5.3 build,, dyno numbers soon,, im also running a meth injection kit, which will help out injector cylce duty..
Old Jul 26, 2009 | 07:53 PM
MaxxMitchell's Avatar
I made 490rwhp on 9lbs through a 4l80 unlocked 3500 stall, and have had it on 12lbs before. Stock long block with a GT2-3 cam. Granted I was doing all that on pump gas and lost a ringland, no reason why a forged bottom end wouldnt hold it all day.
Old Aug 19, 2009 | 10:36 PM
blazin's Avatar
http://www.summitracing.com/parts/NAL-12498544/
Can anyone tell me if these will work on a 2002 5.3 with 2000 853 LS1 Heads? Why do they say 02-04 LS1?
Old Aug 19, 2009 | 11:04 PM
yes they will work,, but i would go with mls head gasket.. muliti layered steel,,, hold up to a lot more power.. like 50 bucks a set.. at gm performance.com.. im running the 853 heads on my 5.3.. with ls6 cam. im at currently 13-14 psi,,with meth injection.. i did run out of injector with the 42lbs..i switch to 60lbs injectors.. i have no dyno numbers.. good luck..
Old Aug 20, 2009 | 05:04 AM
blazin's Avatar
they are listed as mls on ws6store?
Old Aug 23, 2009 | 12:21 AM
1BAD_LS1's Avatar
Restricted User
ya they are listed as MLS on www.ws6store.com....
