Feed Line Length?
Old Jul 26, 2009 | 01:12 PM
LS1Silverado05's Avatar
Default Feed Line Length?
Just curious if anyone knows the general length of feed line to go from the port above the oil filter, to a single turbo mounted in front of the motor...
I am wanting to have my parts ordered and here so I can put it together rather than measure and wait. Im not breaking new ground, so Im sure many many guys have the same length feed line for this set up...
I appreciate the help...
Old Jul 26, 2009 | 01:24 PM
dudeman's Avatar
i bought 4 feet of hose and i think i only used 24-30 inches. its somewhere around that
Old Jul 26, 2009 | 01:29 PM
Hey thanks for the quick reply!
So I could probably just go 36" and be plenty safe...
Old Jul 26, 2009 | 01:37 PM
dudeman's Avatar
that should be fine. where exactly is the turbo going to be?
Old Jul 26, 2009 | 01:56 PM
As front and center, in front of the crank pulley/water pump area....
Old Jul 26, 2009 | 02:05 PM
dudeman's Avatar
mine is set slightly over to the driver side of the crank pulley. you should be fine with 36" of hose.
Old Jul 26, 2009 | 02:51 PM
How high up is it mounted? Do you run a gravity drain line or a pump and where do you drop in for the drain, front cover or pan? Any issues at all with the angle of the drain line?
I have been pondering drain line set-ups...
Old Jul 26, 2009 | 03:11 PM
dudeman's Avatar
you know, it not up as high as i wanted it? it drains to the front of the pan on the driver side of the crank pulley. i dont know what happend when i was doing it, but it sits almost level. i run a 10an 90 out of the turbo but i only run a 1/2 inch line. i couldnt get a 5/8" rubber hose to stay where i needed it. i havent had any issues. i thought for sure the first time out i would destroy something, but i didnt. if i where to do it again i would mount the turbo higher and run the drain line to the front cover.
