turbo 5.3 numbers???
1)Should i get 317 heads or just use my 241's
2)Should i get an ls6 cam or reuse my 227/231 614 617 112+2
3) Do i really need ARP Head/Rod bolts?
4) How much boost should i be looking to run with my FMIC no meth?
If i reuse everything off the ls1 i could do the 5.3L for $600!
Thanks!
Blaine
2. Id sell it and get an LS6 cam
3. I dont have any of that stuff mines held up.
4. I run 15psi and no probs. Havnt tried more. except the 50 shot of spray occasionally....ok quite often.
I have a stock set of 317's I pulled off the block I'm using for my 408 so I'm debating putting those on, but not sure on the cam since I have my comp cam for the 408. Worth going to a z06 cam honestly? I ALMOST got one for my ls1 when I had my TA (rear mount mp T70 @ 8psi). I have a big intercooler with 3" in/out (31x12x4") I'll be using, would rather not spray meth but 15psi would be hilarious, even if it did grenade it'd still be worth the $500 invested, lol. Great build, will subscribe to this one!
Im gonna toss it in my notchback with some 317 heads and see what itll do with a turbo, prob gonna do rod bolts though just to be safe. My plan is to see how much fuel economy i can squeeze out of it as well as power, I wanna run E85 too. Should be a pretty fun lil toy to mess with for this winter and next year. Then just build myself a mean LSX block on the side and take my time with it. Downtime sucks!!!
Shifts at 5860 last time out.
thr stock cam was designed to power heavy vehicles that move/pull weight.
i have a 4.8 that i would like to use to pump some serious psi. 20+ if possible thru stock bottom end and oe heads.
i would like to keep the bottom as oe as possible, even the rod bolts.
the motor i have is a low miles, like new 08 version with the better, rods and bolts,pistons and rings 58x.
BUT the darn car pulls HARD to 5500-5600 then drops to NOTHING! It woud put down ALOT better numbers if it would pull past 5500rpm....
Also on the dyno graph the tq and hp stay almost the same instead of the tq slowly dropping when they cross.... kind of crazy! Never seen a dyno graph like this..... not sure what is wrong.
Springs are good, plugs are tr8's, no KR, not sure what the problem is!!!!!!
ANY ideas??????
http://s721.photobucket.com/albums/w...dynoday014.flv
The real questionis why the drop? What injectors? pump? fp? Is pressure dropping?
So far the turbo van with a z06 cam lseems to like being shifted at about 5800. A lot lower then I thought.
60lb injectors, walbro pump single right now but i have a second one to install this weekend, havent monitored FP on a run but the afr seems to hold steady and not go lean or anything....
