turbo 5.3 numbers???
Old Oct 22, 2009 | 11:34 PM
  #41
1BAD_LS1's Avatar
Restricted User
Originally Posted by 1nasty86
this gives me great hope for my 5.3. what ab fuel? or it blowing your spark out? ive seen spark blown out at upper rpms on 4bangers and it fall on its face like that.
i am running tr8's at 22 gap and stock wires, I have msd's on the way and thinking about trying some tr7's at 28 gap
Old Oct 23, 2009 | 01:17 AM
  #42
skinnies's Avatar
Maxxmitchell made 550 with a tc78 at 11lbs, 4l80e took a dump on the dyno that day also.
Old Oct 24, 2009 | 12:07 AM
  #43
1BAD_LS1's Avatar
Restricted User
must have been a bad day to dyno lol....
his 4l80e died? i thought 4l80e were alot stronger? I beat this stock tranny to 6800 rpm for months with my cam only setup, then i beat the hell out of it with the sts setup for a few months to 6500 rpm, and now its just giving out on this setup....
so i must have had a pretty strong tranny to hold all the power for that much abuse for that long lmao!!!!!
Old Oct 24, 2009 | 08:54 PM
  #44
GMLSX's Avatar
Have a 5.3 iron block short block bored to 3.8988. Makes it an 346ci. Ross dish pistons, Lunati pro mod rods and a stock cryo'ed crank im not using, changed my setup.PM me for details if your interested.
Old Oct 24, 2009 | 10:59 PM
  #45
fuzzyjk's Avatar
Guys what about the L33 it is a 5.3 came in 05-07 short bed Silverado extened cab. They come with 799 heads (same as the 243 ZO6 heads). It is all aluminum and can be had for short $ I paid $750.00 with 29K miles with everything even the TCA and the computer. Stock is 320HP
Lighter and better heads. I am building a kit car and will be using this....now maybe with a turbo.
Old Nov 2, 2009 | 03:10 AM
  #46
skinnies's Avatar
Running e85, put it on the dyno on Saturday, made 408rwhp on 5lbs and 557rwhp on 11lbs with 19 degrees timing. On 10 degrees timing it made 515rwhp. My rx7 went 144.7mph with this power.
Old Nov 2, 2009 | 09:56 AM
  #47
ls1CANTU's Avatar
i made 649HP to the wheels on my 08 chevy truck. that was on stock 5.3 with cam kit. i was running 16 psi. this numbers are from a mustang dyno too
Old Nov 2, 2009 | 01:33 PM
  #48
IT_SS's Avatar
L33 is ****!
pm me if you know where i can get one!
Old Nov 2, 2009 | 07:14 PM
  #49
1BAD_LS1's Avatar
Restricted User
I hope to be there when i get my problem figured out, it was working its way up fast then dropped lol..... (See dyno graph)
Old Nov 3, 2009 | 12:35 PM
  #50
ls1CANTU's Avatar
whats your duty cycle? your not running out of fuel are you? i was runnign tr9's on my 5.3 gapped at .035 and ran only 12*
Old Nov 27, 2009 | 11:14 PM
  #51
1nasty86's Avatar
Turd Gen Guy
finished up my motor. now its a stock shortblock 5.3, 02 ls6 cam, 243 ls6 heads and the weiand intake. also picked up some 42 lb injectors. plans are to get tuned wendsday. hoping for the best for an automatic with 8.9 psi..
Old Dec 3, 2009 | 09:02 AM
  #52
1nasty86's Avatar
Turd Gen Guy
got my car tuned yesterdey. on a very conservative tune with only 16 degrees of timing at 9psi through an unlocked auto made 460.03 hp and 431.89 torque.
Old Dec 3, 2009 | 10:58 AM
  #53
SKINNY69's Avatar
Nice work. That 86 will surely turn some heads.
Old Dec 3, 2009 | 11:07 AM
  #54
1989k1500's Avatar
My friends truck made 681/712 the way it is in the video. 5.3, Z06 cam, Patriot Dual springs, PI 5 disc 3400, 80e, 9.5" rear end, 35" tires, 20" wheels. That was at 19lbs. This pass was at 14lbs, any more and it would jump all over spinning all 4 tires on the launch. And of course its tuned by HellbentS10.
http://www.youtube.com/watch?v=sPzUhQE6iH4
Old Dec 3, 2009 | 11:59 AM
  #55
LS1BLKSS's Avatar
Banned Village Idiot
what size turbo would i need to push around 800 with the 5.3??? PT88?
Old Dec 3, 2009 | 04:19 PM
  #56
ninety4three4's Avatar
To make 800 with low IATs and low boost yes a PT88 would be ok ide think, I am thinking of using a GT4202 (74 MM) to make 700 at around 16-18 PSI with a Z06 Cam, good springs, possibly ported heads, arp rod bolts, mls hg's, and arp headstuds...
Old Dec 3, 2009 | 05:11 PM
  #57
1989k1500's Avatar
Flywheel or wheel horsepower?
That truck I posted was making well over 800 crank hp with a BW S468.
Old Dec 3, 2009 | 05:48 PM
  #58
I think he was referring to wheel horsepower but it may have been flywheel...I am gunning for 700 wheel so in theory around 750-770 flywheel...
Old Dec 3, 2009 | 06:15 PM
  #59
wbwhiteboy's Avatar
If your gunning for 700rwhp, depending on your setup.... that would put you near 900 flywheel hp
Old Dec 3, 2009 | 06:43 PM
  #60
LS1BLKSS's Avatar
Rwhp over 800 at the crank nice!!
