Both APS Turbos went on me
I don't understand why they don't offer a couple different turbo options. You could get the current kit, a "TURBO DELETE" kit for $1000 less, or an upgraded kit for $1000 more. It sucks spending roughly $7000 on a kit only to have to replace the turbos for another $2000.
I would get the LG ones myself but have to save up to get them . I got a set of these as backup. Here is the review from LOWBIRD on them. They are like 400 each with upgraded wheels so good deal if they hold up.
"Hi Al, I just put the one turbo on that I bought from e-bay. I put it on the passenger side when I had the trans out for a new clutch and 9" fabbed rearend install. Pain it the *** with the motor in the car but with the trans down it can be done. It's held up great so far and I've put at least 4k on it, maybe more. I'm still running the stock aps provided turbo on the drivers side and so far no issues. I bought an extra turbo from Kando Dynamics on e-bay because the price was so good and so far so good. It is still wrapped up in box it came in for future use if needed."
It should also be possibly to buy genuine mits centers as replacements for would think about 1000 a piece or maybe far less .Even if you had to buy mits 20gs and then not use the compressor or exhaust housing. LG ones again are superior to stock genuine 20gs but genuine 20gs are super reliable. The aps turbos are just 20g type and aside from their exhaust housing are plug and play center cats. Geniuine mits 20g will not flow as much air as the LG which should do 1400 engine hp max potential compared to maybe 1000 hp engine hp potential tops out of 20gs. And 20g size turbos could still be a bit small on bigger motors than 346.
I was offered to send my dud turbo to aps for possible replacement but didn't want to put the car down as my failure is different ,cracked internal housing but turbo works ok with just oil cooling. And shipping is likely pretty pricey from me to aps them being in australia and not sure want to put another one of theirs on the car and go thru that hassle as said drivers side is simple enough but passengers is more a pain.
johncraig@limitengineering.com
http://www.limitengineering.com
"Thanks, i looked at that part but i wanted to be 100% sure. I'm running the APS kit on a GTO so no dropping the K member for me. My turbos lasted for about 2 years running at stock PSI, at 14PSI they lasted less than a thousand miles. I've already got brand new APS turbos but want to fix the old ones, maybe send them off to see what could be done better. I'm not looking for more HP, just want them to last.
