76mm and no lowend power
Old Aug 2, 2009 | 07:24 AM
raybob's Avatar
Default 76mm and no lowend power
Just got this car last week, car ran good but now doesn' t have any lowend power. I ran codes and seen it has a MAP code and a Knock sensor code. I am going to try and address these issues and see what come up with.
Old Aug 2, 2009 | 11:03 AM
OUTLAWZ RACING's Avatar
Type of kit ? set up info
Old Aug 2, 2009 | 12:16 PM
raybob's Avatar
Default kit
it has the TTI 76 MM street kit, car has 2 codes set, maf and the knock sensor. I will do some more investigating first of the week.
Old Aug 2, 2009 | 12:20 PM
396375's Avatar
What converter?What will it flash to?
Old Aug 2, 2009 | 01:23 PM
Sluggish's Avatar
Put a lower gear in it or a 75 shot.
Old Aug 2, 2009 | 03:22 PM
raybob's Avatar
Default convertor
It has a 3800 stall and a 3.73 gear.
Old Aug 2, 2009 | 03:28 PM
b00sted's Avatar
If it set the SES light for a MAF code, it's probably still running the stock OS tune instead of a 2/3 bar like it should. So you're maxing out the MAF or they failed it and did some fudged up SD tune...Which is probably why it makes **** power anywhere other than in boost.
Old Aug 2, 2009 | 04:17 PM
kikass_z28's Avatar
The knock sensor code is probably pulling some timing making it slower
Old Aug 2, 2009 | 04:33 PM
raybob's Avatar
Default codes
Ok it is like a timing issue but will check the map sensor also. Thanks
Old Aug 2, 2009 | 07:05 PM
Super Slow SS's Avatar
I think there was a confusion on post here .. is it a MAP code or a MAF code and does your car still have the MAF on it?
Old Aug 2, 2009 | 07:19 PM
raybob's Avatar
Default Maf
Yes it still has the MAF on it. What do i need to look at on it? I have seen there are different ones. Mine is stock far as i know.
Old Aug 2, 2009 | 08:15 PM
02anti_vnm's Avatar
he said it ran good but NOW
sounds like a simple problem of the knock sensor and/or the maf going bad and pulling timing hence why its running like crap change those then post back
hope it works out man
