Turbo'ing a '97 Firebird 3.8....where do I begin??
Ok....first, I'm not a newb, I'm just lost on this project....
I've seen 10 different ways to do it and about 500 different prices, but none of them seem to follow the KISS principle that I firmly follow....
So...help me out here guys, what is a realistic single turbo build for a 3.8 that will net me in the 350-400hp range with minimal lag and a relatively simple installation ??, I don't mind having to fab some parts, but manifolds are out of my league so I gotta use something commercially available...Tuning isn't an issue, I can handle that end but I do need to know what parts I'm gonna need....
Am I better off going with a rear-mount setup for ease of install or should I keep it under the hood and deal with the nightmare there for better power??...
Any input ??
Any input ??
Any input ??
Any input ??
You should also get at least 42pph injectors and a new fuel pump. I recommend an intercooler of some sort, but you could run a few psi non-intercooled on the stock motor and pump gas since compression is 9.4:1 in the L36. Colder range spark plugs and some tuning software. That's about it. I might also consider jumping over to a V6 oriented site...
If you REALY want to go ahead and do it, you can probably look at the kits that are being sold for the W-body guys and see if you can use anything from them. Lots of shops specialize in the 3800 series 2 motors. But like most have said, in the long run you would be better off getting a LS1 car.
the sts setup should in theory work since the back ends of the cars should be similiar but i wouldnt take an STS kit for free. id swap a built 370/408 in or sell the car. the ls1 is a much better platform to start with and you'll always be behind the curve. in the long run, it might work out to a similiar price since we all know how cheap FI is
![Cry](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cry.gif)
i myself thought of doing this. yea the ls1 car is a better choice. but the youll get "holy **** thats a v6 that just pulled on my bolt on ls1"
i say go for it. as far as where to start. where does anyone start? manifolds. get some or try and flip yours, get a IC, theres plenty of people that tune them, and if you **** it up, 3.8 parts are cheaper than ls1's.
Someone posted a 6 setup they had built a couple years back. Damned if I could find it with search. Here is all I found.
https://ls1tech.com/forums/forced-in...ercharger.html
An STS will nearly bolt up but the turbo that comes with it won't be sized correctly. And you have a lot less displacement to try to spool it.
If you don't want to mess with manifolds you can do a reverse Y pipe setup which is less than ideal but not too terrible. A couple of guys have got pretty decent numbers out of their setups like that.
Pick a reasonably sized turbo like a 60-1 with a larger T3 hot side and it will spool well and easily make the power you want.
I second investigating v6 site in addition.
