Turbos and AC (YES I SEARCHED)
All kidding aside, previous posts are correct. Most simple turbo kits use truck manifolds pointing forward and the AC unit is in the way. Keeping the AC requires some crafty fabricating.
Let me get this straight, you use the truck passenger mani on the driver side just like normal. Then you use the C6 passenger mani on the passenger side with a small u-bend to bring it forward.
Is this done with the stock K-member or do you need a tubular K? In other words, will simply notching the stock K-member yield sufficient room?
